What's the difference between S4 and RS4 conrod?
As title, thank you.
Here is a photo of the connection rod bolts. The awkward looking bolt is from RS4.
The RS4 con rod big end is 56.95 mm, and S4 is 57.75 mm. The bearing shell thickness is 1.4 mm in RS4, and 1.85 mm in S4. These are not absolutely accurate measurements, but close enough.
The con rods look quite the same. The wrist pin is the same in both.
Users browsing this forum: No registered users and 36 guests
