HELP.. Any Vagcom Guru's
Posted: Sun Aug 05, 2012 9:37 pm
by vikingrs6
Hi
Need some urgent assistance please if anyone can help..
I'm going on Holiday into Europe tomoorrow and need to adjust the xenons for driving in abroad. I found a guide on how to do this with vagcom but when try to do it I'm not getting the On/Off/Next button displayed (see image below)?!.. I have a proper Ross-Tech cable.. What am I doing wrong?!..
Image[/img]
Re: HELP.. Any Vagcom Guru's
Posted: Sun Aug 05, 2012 9:57 pm
by vikingrs6
Just checked the fault codes and I am getting the following which after a quick google might be due to me running lowered suspension (H&Rs)?!.. Anyone else had this issue?.. They seem to be set in the lowest possition?!..
Sunday,05,August,2012,21:11:52:61332
VCDS Version: Release 11.11.3 (x64)
Address 55: Xenon Range Labels: 4Z7-907-357.LBL
Control Module Part Number: 4Z7 907 357
Component and/or Version: dynamische LWR D08
Software Coding: 00050
Work Shop Code: WSC 00000
VCID: 0403E94314003E9
Fault Codes have been Erased
1 Fault Found:
01539 - Headlights Not Adjusted
35-00 - -
Posted: Sun Aug 05, 2012 10:04 pm
by Nobby
Is the suspension set flat - not tilted up at the front?
Posted: Sun Aug 05, 2012 10:09 pm
by vikingrs6
Nobby wrote:Is the suspension set flat - not tilted up at the front?
Thanks for your reply..
Suspension was setup with the front slightly lower, is on level surface when I'm trying to do it?!..
Posted: Mon Aug 06, 2012 7:30 am
by vikingrs6
Dump for the morning people.. thanks for the replies so far..
Posted: Mon Aug 06, 2012 7:53 am
by Mr Footlong
Sure I am wrong but if we are talking about driving on the right hand side, I though there was a physical switch/lever on the backs of the headlamps? Don't blame me if I am wrong and you break something but could have sworn I read that on here somewhere.
Posted: Mon Aug 06, 2012 7:54 am
by Mr Footlong
Posted: Mon Aug 06, 2012 8:41 am
by vikingrs6
Thanks for that, I did hear there was a switch but when I looked I couldn't find anything?!.. Anyone got a guide / images?!.. There seems to be some post saying you have to do it via vagcom and others saying use a switch?!.. confused!..
Posted: Mon Aug 06, 2012 9:22 am
by Maximo
I taken mine to europe a couple of times now and haven't bothered changing the lights over. Not had any problems with people flashing or waving hands at me either. You'll be fine with them as they are.
This make me curious though.
Why have you done this or was it like that when you bought the car?
Posted: Mon Aug 06, 2012 9:37 am
by vikingrs6
Anyone tried this?..
Adaptation
Channel 010: Tourist Solution
When driving in countries where driving is performed on the opposite side as in the native country the headlights must be changed over to avoid blinding the oncoming traffic. When active/enabled the Fault Code 02988 will be stored.
0 = Disabled
1 = Enabled
Note: Only supported for 8P0-907-357-C @ 0020 or newer! Earlier versions require a mechanical Adjustment as described in the Factory Repair Manual.
To change over Bi-Xenon headlights for European driving using VAG-COM. 24-Mar-08
Select Control Module - Select 55 Xenon Range - Select Adaptation - 10
Channel Number - Use the up arrow to move up to Channel 10
New Value - use the up and down arrow to change the ?0? to ?1? - Click Save to store the new value
A yellow Headlight Range Error should be displayed on the DIS together with a beep.
This will beep and show each time the ignition is turned on as a warning that the headlights are set
for European Driving.
An Fault Code will also be added to the log and can be checked using?
Select Control Module ? Module 55 ? Xenon Range ? Fault Codes - 02
Monday,24,March,2008,16:54:14:10474
VAG-COM Version: Release 704.1
Control Module Part Number: 8P0 907 357 F
Component and/or Version: Dynamische LWR H02 0010
Software Coding: 0000012
Work Shop Code: WSC 06314
2 Faults Found:
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 217
Mileage: 24632 km
Time Indication: 0
Date: 2008.03.24
Time: 14:47:09
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 217
Mileage: 24632 km
Time Indication: 0
Date: 2008.03.24
Time: 16:52:41
Channel 09 may need to be changed from ?0? to ?1? for the warning to show and changed back
afterwards.
