MAF issue out of the blue...
Posted: Wed Jul 18, 2012 5:35 pm
Hi guys
Need some help please!!!
We have a 2004 RS6 which has a Unit 20 stage 1 remap (2-3 years back) and also a Milltek decat exhaust.
I spoke to Martin at Unit 20 before we bought it as the engine management light was on due to the decat exhaust throwing off the Lambda sensors. He advised he's have to do a custom remap from scratch as decat is usually for stage 2 remaps. He said he'd re-do the stage 1 remap, with a custom feature to disable the Lambda's (as per a stage 2). For £500.
Thankfully the previous owner included the cats! So, my thought was swap it back to the cats and Lambda sensor issue should be solved. Reset the fault with Vag Com and the engine management light should not come on again. So, that's great in theory.
However... Now on to the problem...
I took the car to a local garage who do a lot of work for us. They are not an Audi apecialist, but do have a very decent standard of work.
The job was to remove the decat downpipes and replace with the original catted downpipes. This involved dropping the subframe, removal of the suspension etc. So a 3-4 hour job.
This was done successfully!!!
However, they have noe advised that the car is idling very badly, and there is a MAF Range Performance fault showing on diagnostics.
Argh!!!
The garage said that it's probably something to do with the remap, and now the car is not getting the correct airflow for the adapted remapped settings.
They also noted that if you remove the airbox (and so also MAF sensors) then it idles PERFECTLY!!!)
So, I called Martin at Unit 20 again to confirm this...
[by the way - Martin is a star - if you own an RS6 and live within a reasonable distance (+ and hour!) then don't use anyone esle!!!]
Unit 20 advised that the MAF settings ARE NOT adjusted as part of the remap, and he immediately said that what's probably happened is that they've broken the MAF sensors if they did not remove the airbox in advance of dropping the engine, or maybe broken some the MAF wires etc.
So I called the local garage again. No, they definitely removed the air box prior to dropping the engine, and we also agreed that it's unlikely that BOTH MAF sensors would break at the same time (although possible!)
They're going to recheck everything in the morning, and check for any damaged wires as well.
So, what do you guys think may have happened here??
The car idles perfectly with the airbox and MAF's removed, and idles like crap with the MAF's in place.
What on Earth could be causing this????
Please help!
Argh!!!
Please help!
