Help - Misfiring and Hesitation
Posted: Mon Jun 11, 2012 9:04 pm
Hi,
I been having a problem with my car. Basically the car won't idle properly, it's like its misfiring at idle and its even worse when moving. When moving from standstill with a small amount of trottle she hesitates/misfires, but when at constant speed everything is fine but when I give her a little bit of trottle she hesitates again and then some times she slowly starts gaining speed then all of a sudden she takes off(as normal). If I give her alot of trottle there is not as much hesitation but there is still a bit. Also when comming to a stop, the revs drop to about 500rpm briefly and then to 750ish rpm, I keep thinking that shes going to stall. I have changed both MAFS, 2 fuel pumps(one failed not so long ago) and all the vacuum hoses have been changed.
The faults I get are as follows:
5 Faults Found:
17628 - Fuel Injector for Cylinder 8 (N86)
P1220 - 001 - Short to Plus - Intermittent
17535 - Fuel Trim; Bank 1 (Mult)
P1127 - 002 - System too Rich
17537 - Fuel Trim; Bank 2 (Mult)
P1129 - 002 - System too Rich
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 -
16692 - Cylinder 8
P0308 - 008 - Misfire Detected
I have searched the forum but and checked the usual bits but I cannot find anything wrong.
I also did some logging, but I don't know what to look for in the logs. One thing in the 1st log is at line 390, you can see the revs drop to 360rpm as I come to a stop. And in log 2 there are alot of misfires.
The weird thing is I know how to fix it... if I plug one of the MAFs out(anyone) it runs as normal, this is really confusing me and my mechanic.
If anyone can have a look at my logs or recommend something it would be appriciated.
Thanks,
Benny
Also, if I clear all the fault codes, disconnect out the battery for about 5 minutes and reconnect, the car runs fine for about 50miles and then starts acting up again.
5 Faults Found:
P0300 - 008 -
16692 - Cylinder 8
Thanks,
Benny
