cam belt kits
Posted: Sat Mar 03, 2012 1:04 pm
by tonyredmond
hi has anyone used these for cambelt kits www.blauparts.com ,or should you
just use main dealer for these, is it worth changing themostat aswell as waterpump,
and alternater, where do you stop? mines due now at 58000 miles
Re: cam belt kits
Posted: Sat Mar 03, 2012 1:11 pm
by Mr V10
Buy genuine Audi from TPS. You want to do the cambelt,watrerpump,thermostat and all the associated rollers/dampers too. Whilst your at it, it is a good chance to replace/repair your intercoolers if they are leaking.
Re: cam belt kits
Posted: Sat Mar 03, 2012 1:38 pm
by Mr Footlong
Tony, DIY job or going somewhere for it?
Re: cam belt kits
Posted: Sat Mar 03, 2012 2:53 pm
by neastev
I did some surfing on the blauparts kits and there was alot of negative comments from the US forums...
Landed up buying an SKF kit with an OE belt, water pump and t stat. Fitted it myself and thought the SKF kit was first class
Re: cam belt kits
Posted: Sat Mar 03, 2012 3:04 pm
by tonyredmond
still unsure who to use, how do you repair the coolers?
Re: cam belt kits
Posted: Sat Mar 03, 2012 3:18 pm
by chunky79
Jd weld. You need a pack for each end of the cooler.
Re: cam belt kits
Posted: Sat Mar 03, 2012 4:21 pm
by Shoppinit
I like SKF for bearings and timing belts. I've worked there and they are a high quality manufacturer.
Re: cam belt kits
Posted: Sat Mar 03, 2012 4:42 pm
by grizz
We're able so supply and post out a full genuine kit if required.
Re: cam belt kits
Posted: Sun Mar 04, 2012 9:40 am
by tonyredmond
thanks Grizz, shame your so far away, do you supply the Jd weld for the coolers that chunky
recommends
Re: cam belt kits
Posted: Sun Mar 04, 2012 9:57 am
by Mr Footlong
You have QST in your sort of area, as well as 4 rings in Dartford (Mobile!) and AMD Essex if memory serves:
http://www.qstuning.com/
http://www.4rings.co.uk/
http://www.amdessex.com/
All these guys have been mentioned on these forums so feel free to go have a hunt :)
Re: cam belt kits
Posted: Sun Mar 04, 2012 10:46 am
by swannny
thats the answer there for you grizz, you need a depot in east anglia, it'd be a little goldmine!
Re: cam belt kits
Posted: Sun Mar 04, 2012 11:04 am
by grizz
Yes we can ,
I've got one in from norwich ....
Re: cam belt kits
Posted: Sun Mar 04, 2012 3:01 pm
by swannny
i got all excited then Grizz, i thought you were going to open a branch in Norwich!
good job i read it twice!
