new TC in but now lots of DTC
Posted: Tue Dec 27, 2011 10:43 am
hello
after getting the dreaded DTC 17125, i got a new TC in last week
engine got out for this operation
while the engine was out, i asked the mechanic to gut the precat
car is stock now but will get MTM remap in january
got the car back on friday and ever since it's a christmas tree on my dash, got lots of DTC that of course never got before the TC replacement
erased them several times but they always come back
i've got DTC for the 2 lambdas before cat if i'm correct
16515 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
P0131 - 002 - Lower Limit Exceeded - MIL ON
16534 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit
P0150 - 008 - Implausible Signal
and i've got a lot of misfires detected
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded
16688 - Cylinder 4: Misfire Detected
P0304 - 001 - Upper Limit Exceeded
16687 - Cylinder 3: Misfire Detected
P0303 - 001 - Upper Limit Exceeded
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 001 - Upper Limit Exceeded - Intermittent
tested the MAF (see attached file) and they look OK, even if i think there is a big difference between both banks, sometimes up to 30g/s at WOT
took out the airbox and put it back again, to check if it were installed correctly
so now,
-are my MAF Ok? because i'm going to replace them and the rubber seals as well
-can the gutted pre cat causes the lambdas related DTC and/or the lean related DTC?
to sum up, WTF is going on with my car?
so now,
