Smaller antennas
Posted: Tue Nov 22, 2011 3:50 pm
Where to get those smaller antennas as shown below...? Are they just replaceable by taking the old one out and new one in, or is it more complicated?
How did you get around the radio reception issue?PhilT wrote:I just used a saloon one. Now it's just there to fill the hole as it is disconnected due to GPS frustration and replacement with an on dash puck.
So why the huge screw-on "bee-sting" thing...chunky79 wrote:Radio is through rear side windows. The small antenna on the roof is for gps
In my experience, the bee sting does feck all except make the car look dateddrybeer wrote:So why the huge screw-on "bee-sting" thing...chunky79 wrote:Radio is through rear side windows. The small antenna on the roof is for gps
It must do something?
My GPS antenna needs replacing - and I've been hoping the smaller one would be possible, but I thought the rear windows only did one wavelength, hence I would need to keep the "bee-sting"...
Good find if that fits well. I have a Calearo DAB aerial being fitted in to the roof directly in front of the current aerial, same angle and looks identical. I was a little weary visually about running 2 big aerials up there so that might be an option for me as I have no intention of using the TV or FM really after the DAB is installed.....mavada wrote:i think this one will fit, but its expensive for a piece of rubber...
http://www.ebay.de/itm/Original-VW-Kurz ... 3a5acf4789
chunky79 wrote:drybeer wrote:So why the huge screw-on "bee-sting" thing...chunky79 wrote:Radio is through rear side windows. The small antenna on the roof is for gps
Took my ''bee-sting'' off cause it lokked <beep>. Radio signal = still great. If you look at the antenna body it says GPS on it
Yeah - I know that works - when I fitted an RNS-E to my B6 I had one of those - and to be fair it was fine...PhilT wrote:Agree with the GPS connector being a PITA, hence why I went for a puck on the dash. 8 satellites
