Page 1 of 2
Got these in the post today
Posted: Wed Jul 07, 2010 8:14 pm
by RS6Steve
I let you know how I get on once fitted on friday
Before anyone comments, I did not pay full whack...[/list]
RE: Got these in the post today
Posted: Fri Jul 09, 2010 2:08 pm
by iaingbrown
OK, I'll bite. Google was my friend and I discovered they are diverter valves. I am none the wiser.Where would you fit these and what would they do?
Re: RE: Got these in the post today
Posted: Fri Jul 09, 2010 2:26 pm
by posterboyj
iaingbrown wrote:OK, I'll bite. Google was my friend and I discovered they are diverter valves. I am none the wiser.Where would you fit these and what would they do?
The diverter (or recirc) valve will put the boost pressure back into the system to aid the turbo spool up.
RE: Re: RE: Got these in the post today
Posted: Fri Jul 09, 2010 2:27 pm
by posterboyj
RS6Steve, why APR over the Forge valve?
Posted: Fri Jul 09, 2010 2:42 pm
by bam_bam
Yeah Steve, ^^^ what he said... why for man?
Posted: Fri Jul 09, 2010 4:14 pm
by monoi
When you close the throttle, the turbos are still putting out pressure and the air has nowhere to go but back to the turbos and work against them turning. It is obviously not so good for the vanes, and it also slows down the pressure build up for the next time you open the throttle.
The valves either let the air out (the whoosh sound on rally cars) or redirect it in the system so there is less loss of pressure whilst the turbos carry on turning.
I would assume the RS6 is already equipped with those, why change them?
Posted: Fri Jul 09, 2010 4:30 pm
by bam_bam
Yep, the RS6 has DVs but they're a little average and made out of plastic IIRC. Like Posterboy, I was wondering what the APRs have over the Forge DVs?
Posted: Fri Jul 09, 2010 5:58 pm
by RS6Steve
Hi All, my OEM were really old and fluttering... I wanted to replace them with some solid ones that would last a lot longer and be more reliable. Not to say the OEM were unreliable.
Anyway, had them fitted today... And what a difference, it feels like a different car. The acceleration is much smoother and more progressive, feels like the boost is holding a lot better.
So the reason I chose the APR over the Forge was fairly simple. Zero maintenance, lifetime warranty and its a diaphragm not a piston.
Posted: Fri Jul 09, 2010 8:47 pm
by bam_bam
Cheers Steve. More reading done, leaning towards adding these to the build list now!
Posted: Fri Jul 09, 2010 9:17 pm
by iR8V10
Do these have any effect on power at all?
Posted: Fri Jul 09, 2010 9:51 pm
by RS6Steve
Dave, I would say increase in BHP only if the previous ones had failed or were worn. What I can say is my car feels faster and tighter. I'm pretty sure my old ones were shot.
The throttle responsiveness has increase and the speed does not seem to drop off as fast when I come of the throttle. I only did about 5 miles after they were replaced today, but will be back on it again tomorrow.
What I will be doing is going to SRR shortly to see if there is much difference in power.
Posted: Sat Jul 10, 2010 9:30 pm
by 500bhp
Got a set a Forge on mine fitted by Grizz.
No comparison of the old plastic stock valves.
Posted: Sun Jul 11, 2010 9:12 pm
by RS6Steve
The car is running fantastic, I just get the occasional boost 'fart' must a have a slight leak under pressure somewhere! Will check out the hoses tomorrow :-)
Posted: Mon Jul 12, 2010 11:11 am
by bam_bam
Haha, boost fart. I'll now have something else to blame my air biscuits on.
Posted: Mon Jul 12, 2010 2:13 pm
by paul_23
They should not make any more power. If the OEM are working well then there should not be any difference but the OEM diaphragms go weak or fail so upgrades like these get them back to how they should be and last longer. If the OEMs are shot (and you can test them but sucking on one side) then new will make it more responsive - less lag etc.
I got Hyperboost valves which are piston type (like forge) and I am pleased with them, although occasionally I get more than a boost fart - if I floor it and then a car pulls out and i have to back off quickly it seems to not release quick enough and it feels a bit like back pressure lurch ....but it could be something else....
