Page 1 of 2
Oil all over my drive way :£(
Posted: Fri Feb 12, 2010 12:18 pm
by marmite
woke up this morning to oil around the front door, nicely washed with the rain last night.
quick look underneath and it appears to be from the o/s/f area
In the house suit off..old trackey on and she is jacked up and under tray off, under holds about .5 litre of oil!
Oil cooler pipe split
No worries I thought I got Audi warranty......not covered!
So looks like I have to get my hands dirty again
Anyone know if it is a pig of a job?
RE: Oil all over my drive way :£(
Posted: Fri Feb 12, 2010 5:05 pm
by johnny11
i noticed my oil cooler pipe corroded a few months ago and went to grizz to sort out, i really wouldn`t attempt as may need new oil cooler if you perish thread on cooler, common prob i hear.
Posted: Fri Feb 12, 2010 5:35 pm
by mushdaffer
I'm no mechanic but audi technician told me similar to what Johnny said, I had to have my cooler and pipes replaced
Posted: Fri Feb 12, 2010 8:29 pm
by marmite
Will find out Monday if I get a chance to play
Warranty won't cover the work if it is caused by corrosion.
Posted: Fri Feb 12, 2010 8:36 pm
by PaulRS6
I had the same problem last year with mine and the warranty wouldn't cover the pipes but did cover the cooler which, as previously said, fails when the tube unions are spannered. My warranty claim covered everything but the supply of the new tubes.
HTH
Posted: Fri Feb 12, 2010 8:38 pm
by marmite
If all goes wrong I will truck it Audi and they can do the cooler under warranty once I lay the pipes correctly
Gave them the heads up already
Posted: Fri Feb 12, 2010 8:40 pm
by marmite
PaulRS6 wrote:I had the same problem last year with mine and the warranty wouldn't cover the pipes but did cover the cooler which, as previously said, fails when the tube unions are spannered. My warranty claim covered everything but the supply of the new tubes.
HTH
was is component cover?
Posted: Fri Feb 12, 2010 8:41 pm
by PaulRS6
was is component cover?[/quote]
I had the named component cover.
Posted: Fri Feb 12, 2010 9:29 pm
by el_ringo
Warranty Direct wouldn't pay for mine when it was leaking. You are pretty lucky it didn't pop when the engine was running. The radiator is soft aluminium so easily damaged. It might be an idea to replace both pipes to be safe.
Posted: Fri Feb 12, 2010 9:39 pm
by PaulRS6
el_ringo wrote:Warranty Direct wouldn't pay for mine when it was leaking. You are pretty lucky it didn't pop when the engine was running. The radiator is soft aluminium so easily damaged. It might be an idea to replace both pipes to be safe.
Good idea - I had all four replaced.
Posted: Sat Feb 13, 2010 2:29 am
by Pau1
No a bad job to do but as Grizz recomended me to do; Cut the old pipe off at the union, with dremel or similar, and don't crack your cooler by trying to torque it off with a spanner.
Posted: Mon Feb 15, 2010 9:44 am
by marmite
Due to my work load increasing
the car has gone to Steve at Rac-london in Kingbury
will let you know the out come
With all the oil under the car it won't rust!!
Posted: Thu Feb 18, 2010 10:15 am
by marmite
car is all done!
New pipes, oil change and new Poly belt fitted, by Steves top RS6 tech Pete
Highly recommend these guys!
New oil cooler not needed once peter cut the nuts with a dremel
so just need to collect and pay!
Posted: Thu Feb 18, 2010 3:15 pm
by MoRS6+
So normally, would whoever was doing this replace the oil cooler? So that technique has saved you a few bob then. Good result.
Posted: Thu Feb 18, 2010 6:21 pm
by marmite
MoRS6+ wrote:So normally, would whoever was doing this replace the oil cooler? So that technique has saved you a few bob then. Good result.
in some cases the cooler splits when undoing the pipes!
The cooler is covered under warranty but not the pipes, hence the job going to Steve
But when I spoke to Audi they said the warranty company came down to look at the car on the last oil cooler job, as they are aware of the issue with removing the pipes. I know the dealer would have not gone to as much trouble to save the cooler!
get her back on saturday
