Rear Inner Parking Sensor
Posted: Wed Jan 27, 2010 11:03 am
by Maximo
Is there a way of replaceing the sensor with out taking the bumper off? I've had a quick look and can get my hand on the sensor but not sure how it disconnects from either the bumper or the cable. There seems to be enough room to get movement but not that much.
If it makes any difference we're talking about an Avant.
RE: Rear Inner Parking Sensor
Posted: Wed Jan 27, 2010 12:08 pm
by Shoppinit
I posted recently about how the sensors are clipped to the bumper.
Shoppinit wrote:They are held in by plastic spring tabs on each side. YOu have to spread the tabs slightly then press the sensor in from the outside. You can then disconnect it.
YOu're supposed to remove the "rear bumper cover" whatever that is. If you can get reach your hand to the sensors, you might be able to remove it without removing the bumper; Maybe someone who has done it can give better advice.
Posted: Wed Jan 27, 2010 5:19 pm
by Maximo
Thanks for that info. I shall have a go over the weekend and see how I get on, hopefully all will be good.
Posted: Sat Jan 30, 2010 10:25 pm
by Stupidog
Did you get it out?
I tried cleaning mine from the outside with some sucess but it aint perfect
Posted: Sun Jan 31, 2010 12:00 pm
by Maximo
Not had a chance so far, still waiting on the replacement sensor arriving. I may have a go at cleaning it in the mean time and see if that helps.
Posted: Sun Jan 31, 2010 10:00 pm
by Stupidog
I tried cleaning it in situ with a dremmel, it kind of worked but make sure you mask the bumper well. I touched the edge and so had to paint that too which shows as it's new paint and no gap like there is on the sensor to hide the work.
I can see it bugging me and a front back bumper paint having to be done :roll:
Posted: Wed Feb 10, 2010 11:42 pm
by Maximo
Had a go over the weekend replacing the sensor, there doesn't seem to be enough room with the bumper on the car. Can any one tell me how I go about removing the rear bumper from an Avant?
Posted: Wed Feb 10, 2010 11:52 pm
by Shoppinit
http://www.rs6.com/forum/showthread.php?t=18725
Sorry. Just read your post properly.
There was a post about it recently. Hold on.
Posted: Thu Feb 11, 2010 12:33 am
by MoRS6+
I'm in exactly the same boat; same sensor.
Watching eagerly...
Posted: Thu Feb 11, 2010 7:45 am
by Shoppinit
Try this:
Posted: Thu Feb 11, 2010 11:20 pm
by Maximo
Going away for the half term break so will have a go in a couple of weeks and report back. Looks like there is a lot og bits to remove along the way.
