Removing front door cards
Posted: Tue Sep 22, 2009 3:22 pm
by alpinestars
Can anyone tell me how do to this please? I know there are screws in the side at the top, but I can't see anything else that holds them in but can't take them off either!
RE: Removing front door cards
Posted: Tue Sep 22, 2009 3:44 pm
by rob8457
Its easy just undo the 2 screws on the sides and pull upwards the hole panal then it will come loose i done it to mine.
Bobby
Re: RE: Removing front door cards
Posted: Wed Sep 23, 2009 10:12 am
by PoRToS
rob8457 wrote:Its easy just undo the 2 screws on the sides and pull upwards the hole panal then it will come loose i done it to mine.
Bobby
Is it the same for the back panels? One of the windows in the back does not want to come back up... Nothing I normally bother about, but if it is that easy, might even take a look inside to fix it...
Posted: Wed Sep 23, 2009 10:36 am
by GardinerG
PoRToS wrote:Is it the same for the back panels? One of the windows in the back does not want to come back up... Nothing I normally bother about, but if it is that easy, might even take a look inside to fix it...
This is
usually caused by the plastic window guides breaking. It's a common fault on the A/S/RS6.
Posted: Wed Sep 23, 2009 12:35 pm
by alpinestars
Bobby
Thanks Bobby, will try this tonight.
Posted: Wed Sep 23, 2009 1:30 pm
by SimonY
Guys,
I had to do this earlier this year cos of a rattle and on searching YouTube also found this via a search on "Audi A6 Power Window Repair"
http://www.youtube.com/watch?v=9UP1Rn7Wj3s
It really is a piece of cake!
Simon
Posted: Wed Sep 23, 2009 3:33 pm
by GarethRS
The hardest part is getting the window switches out, once you have mastered it, its very easy.
Let me know if you get stuck as I have some pictures.
Posted: Thu Sep 24, 2009 4:02 pm
by GardinerG
If anyone needs the part number of the pink plastic window guides it is 4B0 837 463B (when I ordered them from VAGParts in the good old days!
