Juddering from pull off full lock??
Posted: Sun May 10, 2009 9:04 pm
by mattler
When I pull away on full lock there is a wierd juddering/vibration??
Is this normal on an RS6, the wheels are standard but its running Bilstiens
Matty
Posted: Sun May 10, 2009 9:19 pm
by S4WON
yep!..
this...
http://www.rs246.com/index.php?name=PNp ... ic&t=77026
what I will say, is no, I don't have an RS6 (yet), but ive owned 3 other 4WD audis, its pretty common - don't lose sleep, but get it checked if its real bad......
Posted: Sun May 10, 2009 9:39 pm
by mattler
Its not horrendous and somehow seems normal but I know the car has recently had laser 4 wheel alignment done so just thought I`d check!
Posted: Mon May 11, 2009 7:41 am
by ecain63
Its normal for permenant 4wd drive cars to have a bit of 'judder' on full lock. If its really bad then get it checked, but nothing to worry about if not. Its all to do with the wheels turning at different speeds when under full lock, causing grip issues as they fight the diffs.
Posted: Mon May 11, 2009 6:12 pm
by TIMSRS
Yep, mine does exactly this my s6 did the same also. i would say nothing to worry about.
Posted: Tue Jul 28, 2009 11:01 am
by bwinston
my RS4 is the same, i wouldt worry.
Posted: Tue Jul 28, 2009 6:02 pm
by Shoppinit
Normal. There's a fairly interesting explanation on why it does this, but I can't remember what it is.
Posted: Tue Jul 28, 2009 7:37 pm
by ecain63
^^^^^ 4 wheels trying to turn at the same / similar speed when the inside wheel is almost at standstill due to full lock. This causes inside wheels to drag.
Posted: Thu Jul 30, 2009 3:22 pm
by Cornishmoocher
You may also find that the front wheels are touching the arch liner, mine does this, took grizz and i about 30 mins to figure out what it was, driving back and forth on full lock. It is very common- sounds and feels like a graunching bearing.
