Page 1 of 2
H&R and Hotchkis Sway-bars settings
Posted: Mon Mar 09, 2009 2:03 pm
by onlinesys
Hi Gents,
Finally I could get rid of the bloody DRC and install the best combo -- H&R coilovers and Hotchkis Sway-bars.
Did a search but no info on the recommended settings on the H&R and Hotchkis Sway-bars within the RS6 C5 forum.
Can someone recommend a setting for typical UK B-road? We don't have good person like Grizz over here?
Cheers,
RE: H&R and Hotchkis Sway-bars settings
Posted: Mon Mar 09, 2009 2:06 pm
by ChrisS2
The front hotchkis bars are not adjustable, i'd set the rear to hard on the RS6.
Re: RE: H&R and Hotchkis Sway-bars settings
Posted: Mon Mar 09, 2009 2:33 pm
by skyegtb
ChrisS2 wrote:The front hotchkis bars are not adjustable, i'd set the rear to hard on the RS6.
I 2nd that, definitely set the rear to the harder setting.
Posted: Mon Mar 09, 2009 3:23 pm
by onlinesys
skyegtb wrote:ChrisS2 wrote:The front hotchkis bars are not adjustable, i'd set the rear to hard on the RS6.
Thanks for your info. How about the front setting?
Also, is there any recommended ride height settings (front and rear) if the rear setting is the hardest? Apologize if I am asking silly question.
RE: Re: RE: H&R and Hotchkis Sway-bars settings
Posted: Mon Mar 09, 2009 11:07 pm
by Gavc500
Hotchkis fronts are one setting only, rears have two settings, from memory the settings are about 50% and 65% stiffer than OEM, so use the stiffest setting.
Re: RE: Re: RE: H&R and Hotchkis Sway-bars settings
Posted: Tue Mar 10, 2009 3:16 am
by onlinesys
Gavc450 wrote:Hotchkis fronts are one setting only, rears have two settings, from memory the settings are about 50% and 65% stiffer than OEM, so use the stiffest setting.
Thanks GAVC450. How about the H&R? Is it just a matter of personal preference for the ride height and/or the condition of the road or something more complicated??
RE: Re: RE: Re: RE: H&R and Hotchkis Sway-bars settings
Posted: Tue Mar 10, 2009 9:07 am
by philroach
just had mine done by Grizz . He recommended the softer setting for the arb ,height is a personal preference , doesnt effect ride , unless it is so low you lose your sump on speed bumps , he lowered mine so you cant see the top of the tyre in the rear arch , very nice
Phil
Posted: Tue Mar 10, 2009 9:44 am
by MartynC
Griz set mine the same....softer setting and kept the optional 10mm lowered setting that I opted for when I bought my Plus.
Sure has improved the car.
MartynC
Re: RE: Re: RE: Re: RE: H&R and Hotchkis Sway-bars setti
Posted: Tue Mar 10, 2009 9:47 am
by onlinesys
philroach wrote:just had mine done by Grizz . He recommended the softer setting for the arb ,height is a personal preference , doesnt effect ride , unless it is so low you lose your sump on speed bumps , he lowered mine so you cant see the top of the tyre in the rear arch , very nice
Phil
Thanks Phil for your info. I will try to follow your setting of "can't see the top of the tyre in the rear arch"
Posted: Tue Mar 10, 2009 12:21 pm
by philroach
MartynC wrote:Griz set mine the same....softer setting and kept the optional 10mm lowered setting that I opted for when I bought my Plus.
MartynC
I nearly wet myself , swooping down on to the M56 , and not having any bodyroll , damn it has stiffened things up !!
Posted: Tue Mar 10, 2009 12:24 pm
by Cornishmoocher
Told ya.........
Posted: Tue Mar 10, 2009 12:34 pm
by GardinerG
^^^ like he said. I can't wait till the track day at Bedford now... mmmm
Posted: Tue Mar 10, 2009 8:40 pm
by Gavc500
OK, well I'm surprised that you buy stronger ARB's and use the lesser rear setting which admittedly is 50% stiffer than OEM, however the stiffer setting gives a little more at 65%.
So if you use the slightly softer setting on the rear ARB, it allows more flexing at the rear and the front wheels do not have to do as much work to get round the corner....., but if you use the stiffer setting, it can cause the front to work harder and understeer on cornering..... unless you use the ackerman setup principle of slightly toeing out the front.... then you have a go kart effect on cornering, goes round on rails!!
Anyway all personal preferences, just have fun with the setup.
Posted: Tue Mar 10, 2009 10:20 pm
by BigMo
I think a 10mm drop will suffice. Any lower and you may find problems with some of the Wilson carpark ramps!!!
Posted: Wed Mar 11, 2009 1:15 am
by onlinesys
Gavc450 wrote:OK, well I'm surprised that you buy stronger ARB's and use the lesser rear setting which admittedly is 50% stiffer than OEM, however the stiffer setting gives a little more at 65%.
Hmmmmmmm!! Seems very sensible setting. Is it easy to change from stiffer to softer setting on the rear ARB so that I could try both or I would have to pay a lot on the labour fee?
