Page 1 of 2
RS6 dump valves
Posted: Sat Mar 07, 2009 7:02 pm
by ecain63
When we roaded the car this morning, the operator managed to break the nipple off the right hand dump valve while removing his sensor. No way he could repair it and the management light came on straight away. Is this a cheap repiair or would i be better off going for an after market upgrade? I know a better valve helps turbo spoole up. Any recommendations/
RE: RS6 dump valves
Posted: Sat Mar 07, 2009 7:05 pm
by grizz
Get a pair of 710n dv's , they are fitted on tt's . Or you can use some nice forge 007's.
RE: RS6 dump valves
Posted: Sat Mar 07, 2009 7:24 pm
by ecain63
cool. do they have any advantage over standard?
RE: RS6 dump valves
Posted: Sat Mar 07, 2009 7:26 pm
by grizz
Last longer..
RE: RS6 dump valves
Posted: Sat Mar 07, 2009 7:37 pm
by ataRS6
how much do these cost an are they they the ones that expell with the whooshing noise??
Re: RE: RS6 dump valves
Posted: Sat Mar 07, 2009 8:24 pm
by GardinerG
ataRS6 wrote:how much do these cost an are they they the ones that expell with the whooshing noise??
£85+VAT each. No, thankfully.
RE: Re: RE: RS6 dump valves
Posted: Sat Mar 07, 2009 8:29 pm
by Cornishmoocher
I want some electronic Dv's that make a farting noise as they dump. Moocher aged 13 3/4.......
Posted: Sat Mar 07, 2009 9:01 pm
by Jess
I would quite like that whoosh sound, is it easy to add a suitable dv that enables this? If so how much, and how long to fit?
Posted: Sat Mar 07, 2009 9:11 pm
by grizz
DON'T Fit a "whoosh" type dv...... It'll cause all sorts of fault codes ..
Posted: Sat Mar 07, 2009 9:28 pm
by GardinerG
^^^ as he said!
Audi DVs = Diverter Valves (aka recirculation valves) not Dump Valves.
Posted: Sat Mar 07, 2009 9:31 pm
by Golfather
I've had Bailey DV's on my S4 and RS6.
Quicker spool up over the 710N, you do feel the difference
Posted: Sat Mar 07, 2009 9:38 pm
by Cornishmoocher
Grizzwold, how often should I service my Forge DV's?
Posted: Sun Mar 08, 2009 9:27 am
by ecain63
the 007's look alot more reliable than the plastic fantastic OEM parts. is it worth the upgrade? And have you read the claims of 'an extra 5-10bhp'? Are they justified claims?
Posted: Sun Mar 08, 2009 9:35 am
by Cornishmoocher
Forge Dvs are billet aluminium, and as for extra hp...I doubt it.
Re: RE: Re: RE: RS6 dump valves
Posted: Sun Mar 08, 2009 9:37 am
by GardinerG
ecain63 wrote:the 007's look alot more reliable than the plastic fantastic OEM parts. is it worth the upgrade? And have you read the claims of 'an extra 5-10bhp'? Are they justified claims?
They increase BHP about as much as folding the rear seats down.
Well, if your current DVs are leaking then they might increase BHP back to its proper level!
