Need a replacement ABS module
Posted: Sat Aug 10, 2024 5:04 pm
by ALE-RS6
My ABS module was sent away for refurbishment due to ongoing issues, and they have come back and said it's beyond repair. They said it has previously been repaired once before. So I'm on the hunt for a 2nd hand or refurbished unit part ref '4B0614517AD'. If anyone by chance has one or know of someone that might, let me know or send me a DM.
The car is in with an Audi specialist at the moment and they sent the module away to a company they use frequently and it's the first time they've not been able to repair one (typical! - didn't catch the name of the ABS repair company).
Re: Need a replacement ABS module
Posted: Sat Aug 10, 2024 5:16 pm
by srichards
Posted: Sat Aug 10, 2024 5:19 pm
by srichards
There's 3 that look visually similar on the passat page as well:
https://www.ecutesting.com/product-cata ... -combined/
Posted: Sat Aug 10, 2024 5:32 pm
by ALE-RS6
Thanks bud, I think they offer a refurbishment service rather than the actual replacement part?
Posted: Sat Aug 10, 2024 5:43 pm
by srichards
You could contact Ecu Testing and ask them if they can repair one that has already been repaired. They also may be able to tell you whether the ones that look the same are the same and are interchangeable. If they are that gives you a bigger pool of used ones to access.
Posted: Sat Aug 10, 2024 6:01 pm
by ALE-RS6
Yeah I'll try contact them and see what they say. Have you had any dealings with them in the past?
Posted: Sat Aug 10, 2024 6:08 pm
by srichards
No but I think others have used them before and found them ok.
Posted: Sun Aug 11, 2024 8:21 am
by 111marc111
I used "ecu testing" for three abs pump on my Rs6 and they were fab. Also used them for a bmw and they solved that one too.
Their website is also very good. Have a look because I'm sure they not only refurbish your sent in unit but they also sell refurbished replacements.
Have a look on their website. They are defo worth a call
Posted: Sun Aug 11, 2024 10:39 am
by ALE-RS6
That's good to know, thanks. I've contacted ECU testing and I'm going to speak with the garage in the morning to get some more details on the faulty unit.
Posted: Sun Aug 11, 2024 1:47 pm
by Felix2566
Another positive for ECU testing, they repaired my ABS module too
Posted: Mon Aug 12, 2024 7:37 pm
by ALE-RS6
I spoke with the garage this morning and they did in fact send it to ECU testing. They didn't have a suitable replacement either unfortunately. There's some reassurance knowing ECU testing looked at it. So after much digging, I managed to find a second hand unit from a breaker sold in working condition. The part should arrive mid week for fitting so fingers crossed.
Posted: Mon Aug 12, 2024 7:47 pm
by ALE-RS6
Forgot to mention, I also received a quote for a special order new unit from Germany for the princely sum of £3,300.00
Posted: Tue Aug 13, 2024 12:29 am
by hahnmgh63
Until guys figured out the coding for the ABS to work with the 6spd manual there were some guys that used a Passat unit so there must be one around the same year that is pretty close, if they got it work with the 6spd they can probably get it to work with the crappy ZF 5HP.
