Page 1 of 2
Where to get all suspension arms and bushes
Posted: Thu May 30, 2024 3:49 pm
by Frazz82
I am going to be replacing all suspension bushes and arms front and rear shortly but I have had problems in the past with getting the wrong parts even when it says it will fit the c5 rs6.
Where's best to source all the arms and bushes I need.
Re: Where to get all suspension arms and bushes
Posted: Thu May 30, 2024 3:52 pm
by Frazz82
https://034motorsport.co.uk/control-arm ... tgQAvD_BwE
Was looking at these for the front.
Posted: Thu May 30, 2024 4:43 pm
by Nobbsy
Just replaced all the fronts on mine with these. Good OEM quality and fitted perfectly.
https://www.autodoc.co.uk/lemforder/1273462
Posted: Thu May 30, 2024 9:23 pm
by Frazz82
Nobbsy wrote: ↑
Look ok them šŸ‘Œ.
I am struggling to find sets for the rear.
Posted: Thu May 30, 2024 9:41 pm
by TOPMAN
Nobbsy wrote:Just replaced all the fronts on mine with these. Good OEM quality and fitted perfectly.
Good choice, this is the kit I’d go for if doing it again Image
Posted: Fri May 31, 2024 8:52 am
by srichards
I had the rears done and just had the originals powder coated and the bushes replaced. It was rather pricey. I think the arms were £800 each from Audi or some other ridiculous figure then and I don't think there were any rears on autodoc.
Has anyone got part codes for them?
There's a lot of stuff listed on autodoc now and some of the arms seem to do front and rear.
https://www.autodoc.co.uk/spares-search ... %5B%5D=273
Posted: Mon Jun 03, 2024 10:24 pm
by Frazz82
srichards wrote: ↑
Also keen to find out the part numbers if anyone can put thrm up.
Posted: Thu Jun 06, 2024 9:30 pm
by bilko1
Not sure if this is what you are looking for viewtopic.php?f=2&t=106104&hilit=meyle+ ... nsion+arms
Posted: Fri Jun 07, 2024 5:50 pm
by Frazz82
Phoned Awesome GTI for a quote on some powerflex bushes comes in at nearly £1000. I have also emailed AutoDoc to see if they can price it up as there is loads of choices on the website and didnt want to get the wrong ones.
Posted: Sun Jun 09, 2024 12:17 pm
by Felix2566
Be careful with the lemforder kits for the front. The lower arms supplied are not correct for the RS6. They are available from Autodoc, but need to be ordered separately.
What I bought from AD:
Front arm set 3553701 Lemforder
Lower arms 45958 Febi Bilstein (these are AD part numbers)
Make sure you confirm the part numbers are correct for yourself!
Posted: Sun Jun 09, 2024 12:20 pm
by Felix2566
I use LLL Parts website for parts diagrams and numbers, have bought a few things off them in the past.
Audi tradition have a few things in stock for the RS6, but parts are thin on the ground for them
Posted: Mon Jun 10, 2024 12:32 pm
by Frazz82
Felix2566 wrote: ↑
Just looked at LLL Parts looks good. It's what I was after for diagrams and part numbers so cheers mate šŸ‘
Posted: Mon Jun 10, 2024 4:37 pm
by Nobbsy
Felix2566 wrote: ↑
Out of interest, what was the issue with the Lemforder lower arms? Mine looked the same and fitted ok, since been 4 wheel aligned and all seems good.
Posted: Tue Jun 11, 2024 12:19 pm
by Felix2566
From memory they are a tiny bit shorter (the non RS specific part number) , I'm sure I put them side by side and there was a noticeable difference.
But if yours has aligned up ok maybe its not true. The part number is different between the RS and the lower models, maybe it's the bush material rather than the physical dimensions
Posted: Tue Jun 11, 2024 3:18 pm
by Felix2566
viewtopic.php?t=93727
Maybe I was talking rubbish....
