Page 1 of 2
Gearbox sump bolts
Posted: Tue Dec 19, 2023 4:32 pm
by Nobbsy
Afternoon all, decided to change oil and filter in transmission today. Got a kit genuine ZF kit from auto doc with new magnets, o rings and gasket, had seen some from other suppliers with sump bolts. I can see why now! 3 were already round before i started, managed to get them out with a little heat and butchery. Good news was fluid all clear and no rubbish on magnets, bad news i have to source new bolts. They appear to be t27 torx and 27mm long and there's 26 of them. Had a look online and there are some crazy prices , anyone know if there is an alternative? Worst case, i have a spare gearbox that i could borrow some bolts off but would be good to replace them.
Re: Gearbox sump bolts
Posted: Tue Dec 19, 2023 4:43 pm
by Shoppinit
Why don't you just get some hex socket from Accu? They are just metric thread bolts.
Posted: Tue Dec 19, 2023 4:50 pm
by Nobbsy
They do look like m6 bolts, was checking as they have a taper on the end and don't want to bugger the casing. Some places are £3-£4 a bolt, god only knows what audi would want!
Posted: Tue Dec 19, 2023 4:53 pm
by Nobbsy
Posted: Tue Dec 19, 2023 5:00 pm
by Nobbsy
Posted: Tue Dec 19, 2023 5:17 pm
by Shoppinit
I'd be worried that they'd corrode too quickly. Think I'd go for the zinc plated versions.
I thought they were smaller than M6, but you can soon check by measuring.
Posted: Tue Dec 19, 2023 8:28 pm
by Mɐʇʇ
I believe they are M6 x 23mm. If you are replacing with your own ones, you'll need socket head, not hex head - if I were replacing mine now (I actually DID replace all mine with OEM a few years back) I'd also consider stainless, and you'll need 26 of them. But why not just go with this - if I were replacing mine again, I'd probably just use these :
https://www.autodoc.co.uk/metzger/13820734
Posted: Tue Dec 19, 2023 9:50 pm
by Nobbsy
Cheers, your search seemed to work better than mine. Will just order those, will work out expensive though as i had a pair of front discs in my basket
Had thought about the stainless but was concerned they would seize in aluminium.
Posted: Tue Dec 19, 2023 9:55 pm
by Mɐʇʇ
I always lookup the part number separately and then search based on part number - compatibility guides are always just a guide, they're not the bible. So ultimately loads of bits fit the RS that are not listed in the compatibility guide.
Re. Stainless - it's all a bit oily down there, although if in doubt a bit of perfect seal on the threads and they'll never seize in. (I have a boat too - lots of stuff is stainless bolts into ali)
Posted: Wed Dec 20, 2023 11:21 pm
by Nobby
Some of mine were rounded so I’ve bought about 10 from autodoc. Not used them yet though - servicing the gearbox when it gets a bit less damp outside.
Posted: Thu Dec 21, 2023 8:37 pm
by Nobbsy
Oddly enough, the bolts in my 'spare' gearbox that is awaiting a rebuild are like new. Will borrow a few of those and replace them when auto doc deliver my order. Hopefully get the sump back on and refilled with oil tomorrow. Any tips? have
Vagcom and filling adapter.
Posted: Thu Dec 21, 2023 9:50 pm
by Shoppinit
Have you familiarised yourself with the procedure?
Posted: Thu Dec 21, 2023 10:06 pm
by Nobbsy
I think so, service kit came with instructions with gearbox temp, running through gears etc.
Posted: Thu Dec 21, 2023 10:13 pm
by Shoppinit
Plenty of time to get it all in before it gets up to temp. First time I did mine I was trying to squirt it all in as fast as possible then waited for ages for the box to finish. I’m sure there’s a massive innuendo in there somewhere.
Posted: Fri Dec 22, 2023 7:01 pm
by Nobbsy
All done! Seemed to go well, managed to get 6.5l back in there which seemed a lot considering the threads that i have read. Maybe because it was on the ramp with the sump off for a couple of days, all those drips add up.Far too damp and muddy for a test drive but all seemed fine in the workshop.
