Slight misfire
Posted: Tue Dec 06, 2022 11:20 pm
by alexmac
Hi all,
I have a slight misfire under heavy load, it’s not a full loss of power but it certainly hesitates. Ran diagnostics and nothing has come up accept the following.
0010752
18010 - power supply terminal 30 - P1602 - 002 - voltage too low - intermittent
It had new coilpacks and spark plugs last year. Guessing it could be a boost leak or a leak on the MAF seals?
Also have two fault codes for the HVAC
High pressure sensor (G65) open or short to plus
Air quality sensor (G238) faulty
Is this the reason my aircon isn’t working?
Thank you
Alex
Re: Slight misfire
Posted: Tue Dec 06, 2022 11:36 pm
by d-9
Intermittent Terminal 30 voltage too low usually means its had a flat battery at some point.
High pressure sensor G65 will stop the AC working.
Re: Slight misfire
Posted: Wed Dec 07, 2022 7:06 am
by Shoppinit
High pressure sensor problem = no AC. Common problem. Easy fix.
Re: Slight misfire
Posted: Sat Dec 10, 2022 12:20 pm
by alexmac
Would these faults explain why my fans wind up straight away on a cold start?
Re: Slight misfire
Posted: Sat Dec 10, 2022 10:33 pm
by Shoppinit
That could be the temperature sender. Although I’ve got a feeling that if your AC is on, you’ll get that jet engine starting up fan noise. Check the 2 temps coming from the temp sender.
Re: Slight misfire
Posted: Wed Dec 28, 2022 9:01 pm
by Foxmeister
Is it used regular?
Mines can sit for 2-3 months if im busy as i have other cars, and it doesnt like old fuel, after about 4 months one time i took it out and it was hesitating, flung half a tank of fresh juice in and it was fine again after that
Re: Slight misfire
Posted: Thu Dec 29, 2022 2:11 pm
by Foxmeister
Shoppinit wrote: ↑Sat Dec 10, 2022 10:33 pm
Shopp, I PM’d you but it’s disappeared, can you receive or is your inbox full???
Re: Slight misfire
Posted: Thu Dec 29, 2022 5:12 pm
by Shoppinit
Nah. Not full and nothing received.
Re: Slight misfire
Posted: Thu May 04, 2023 6:03 pm
by alexmac
Haven’t had a lot of time lately to work on my car but now the weather is slightly improving I’m trying to get everything sorted before the summer comes. I took the car to my local garage yesterday and asked them to smoke test the boost pipes and it turns out that both my intercoolers are badly leaking.
They’re going to see if they can get a set of oem ones and I am looking to see what I can find online. Looks like you can spend £1500 on Wagner ones which I don’t want to do or Airtech ones for £688. Does anybody have any experience with airtech? Is it better to just buy oem ones if I can get hold of them?
Re: Slight misfire
Posted: Thu May 04, 2023 8:17 pm
by Shoppinit
The oem won’t be cheaper than the Wagner and probably not available anyway. Plus they are <beep>.
Re: Slight misfire
Posted: Thu May 04, 2023 8:33 pm
by alexmac
Shoppinit wrote:The oem won’t be cheaper than the Wagner and probably not available anyway. Plus they are <beep>.
I can’t justify spending that much, I might try the Airtech ones instead.
Re: Slight misfire
Posted: Thu May 04, 2023 9:50 pm
by Shoppinit
Sure, there have been a few alternatives mentioned over the years. Have a search through the threads.
Re: Slight misfire
Posted: Sat Jun 10, 2023 9:32 am
by alexmac
Shoppinit wrote:High pressure sensor problem = no AC. Common problem. Easy fix.
Been waiting over a month now for my local garage to get me a new pressure switch but it still hasn’t dispatched apparently. I have found one on euro car parts and it says it’s compatible with my car. Would somebody mind having a look to see if it’s the correct one please?
https://www.eurocarparts.com/p/mahle-ai ... -236440040
Re: Slight misfire
Posted: Sat Jun 10, 2023 10:30 am
by Shoppinit
It cross references with the OE part number 8E0 959 126 :
https://www.auto-doc.ie/mahle-original/15289090
I'd take the risk. Worse case, send it back.
Cheaper at carparts4less with code SUMMER - 20% off.
