Cleaning a F125 switch
Posted: Fri Dec 03, 2021 6:37 pm
Has anyone ever refurbished a F125 switch? I have just has the fun of replacing the F125 for the 2nd time in my RS ownership. First time was 2012 and done it again today. First time was due to gearbox limp mode, all of the gear lights on the dash being illuminated and the following fault codes.
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FB
Component: AG5 01L 4.2l5VT RdW 1214
Coding: 00001
Shop #: WSC 00000
VCID: 6CDC191B1C90D69
1 Fault Found:
17090 - Transmission Range Sensor (F125)
P0706 - 35-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AD
Component: ESP 5.7 RS 6 2310
Coding: 06697
Shop #: WSC 00000
VCID: 63CE7227F14E991
1 Fault Found:
01119 - Gear Recognition Signal
35-00 - -
The change today was not due to limp mode (it never actually put the car in to limp mode), but was due to a constant un-clearable code in the ABS module which prevented the car being started with the key. Strangely the fault was registered as 'intermittent' even though it would return immediately after every scan I made with the Vagcom.
Coding: 06697
Shop #: WSC 00000
VCID: 63CE7227F155BF913C-5120
1 Fault Found:
35-10 - - - Intermittent
Anyway, I swapped in a spare 2nd hand F125 I had and all is now good again, car starts on the key and fault code gone, but ideally I will get a brand new replacement or clean and re-furbish one of my old ones and fit it. Due to the pretty simplistic nature of these switches I think that a fully cleaned and re-greased used one would probably be as good as a new one, so I am looking for your suggestions as to how best to go about cleaning the internal contacts and what grease I should use to re-grease the rails.
Below is a picture of the F125 I opened this afternoon. As can be seen some of the electrical contacts are quite dark looking, but I don't know what might have caused this. I already buzzed all cables through with the multimeter and all tested fine for continuity, the same for the rails - everything appears to be OK, but I would not re-fit this without a full clean etc.
So, if you did this, what did you use? A chemical, a light acid solution, fine sandpaper? What grease did you use?
Looking forward to suggestions. Here are the pictures:
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
Coding: 06697
Shop #: WSC 00000
1 Fault Found:
35-00 - -
Coding: 06697
Shop #: WSC 00000
1 Fault Found:
