Engine out for gearbox- what else?
Posted: Wed Sep 16, 2020 1:56 pm
by ZedRS6
Hi guys
So currently getting my gearbox refreshed and have the engine out, I’m giving the turbos on for a refresh also, just wanted to ask what else I should be looking at to change while the engines out?
Re: Engine out for gearbox- what else?
Posted: Wed Sep 16, 2020 11:19 pm
by Mɐʇʇ
It's a fairly standard list. Depends on mileage, but assuming it's an 80-100K car, I'd say most of these are due:
* Bufkin Pipe
* EGT sensors
* Upper Lambda Sensors
* F125
There are other bits too - intercoolers, MAFs, but they're all doable engine in.
Posted: Thu Sep 17, 2020 11:59 am
by steve2003rs6
Have a good check on the steering rack and associated pipe work. Caught me out last year and a nightmare to get at.
Posted: Thu Sep 17, 2020 12:12 pm
by Foxmeister
Timing belt seeing as its out and might be due?
Posted: Fri Sep 18, 2020 10:26 pm
by Mɐʇʇ
Yeah, certainly while the lock carrier is off, much easier to do.
Posted: Mon Sep 21, 2020 10:14 pm
by Capt Ric
Zed, where did you go for the gearbox refresh? Please give some feedback when done. Thanks.
Posted: Mon Sep 21, 2020 10:38 pm
by ZedRS6
Capt Ric wrote:Zed, where did you go for the gearbox refresh? Please give some feedback when done. Thanks.
I Went to Auto Trans in Wembley I will def give feedback once the car is back on road.
So far I’ve
Refurbished the turbos
Replaced rear main seal
Rocker cover gaskets
May do chains and tensioners
Posted: Tue Sep 22, 2020 8:46 am
by Mɐʇʇ
Tensioners, or at least the shoes, isn't a bad shout - depends on mileage.
Although is also doable engine in following Nobby's guide.
