Rear view mirror failed
Posted: Wed Jun 17, 2020 7:18 pm
Well this could have been a lot worse...
I jumped in the car and noticed what looked liked water drops on the gear selector surround.
The kids had been playing with the hose earlier and my initial though was they must have got a bit through the window even though they were playing along way away from my car.
On closer inspection the fluid wasn’t clear, then I started to worry. I tasted a little of the fluid and straight away I thought whatever this is its corrosive!
I took a quick picture (just in case I needed to ask you guys what might be going on) and got to work cleaning it up.
Unfortunately I was right, it was as corrosive. Thankfully, and very straggly, whatever it was looked to have only just happened. No damage had been caused to the piano black and gear selector surround nor the leather or leather look trim. Some damage has happened to the window adjuster and menu surround but they’re very easily replaced.
With no idea what might have caused this I was undecided as to weather or not I should drive the car. My initial thought was that maybe it was a hydraulic fluid but nothing I thought of made any sense.
Sod it, let’s start the car and brace myself to be engulfed in a fire ball or hosed down in hydraulic fluid. NOTHING!
So I decided to drive it, before pulling away I check my rear view mirror and I see a shadow. The mirror must have got hot in the and burst. I think a drip must have formed under the mirror and as I jumped in the car and closed the door the drip fell.
Has anyone else had this issue? I honestly think this could have been so much worse with the corrosive fluid taking out a lot on the interior. Currently I’ve got the mirror wrapped up until I find time to remove it. Hopefully not too hard to replace.
