Page 1 of 2
Vaico Camshaft Adjusters - Thumbs Up
Posted: Sat Jan 11, 2020 7:23 pm
by Mɐʇʇ
Just a quick post seperate from the how-tos to note that the Vaico camshaft adjuster I fitted as an alternative to OE is good. 👍 They're about half the price of OE, but quality of the unit seems to be on a par with OE (I suspect comes out of the same factory - that casting looks identical bar the audi logo), and cam timing & phasing is spot in.
This is my car this morning - one adjuster is OE with new shoes (sourced as per nobby's thread), the other adjuster is the replacement Vaico one:
Can't argue with that. (And Tony - I left it warm up fully this time so idle speed is correct. :bigblink: )
I'll also vouch for the adjuster shoes from Nobby's thread. You can see on my OE phaser, it's restored the timing spot on as well. Those shoes also look identical to the ones on the Vaico ones and are superior to the Blauparts ones.
Obviously also tested the timing change all works correctly to - all reported corrected out of VCDS.
(Phew - didn't fancy taking it apart again)
Re: Vaico Camshaft Adjusters - Thumbs Up
Posted: Sat Jan 11, 2020 7:56 pm
by Shoppinit
Great news. Might get a couple for future spares.
Posted: Sat Jan 11, 2020 11:23 pm
by IchBautAuto
HeHeHeHe.......
Annoyingly, the cam chain adjusters aren't common for the V6 and V8. I've one brand new AUDI adjuster bought for the RS4 and it would have been nice for it to be a common part but not to be. 078 rather than 077.
Posted: Sun Jan 12, 2020 7:09 am
by Gregstv
Anyone tried Hamburg-Technic adjuster? I purchased one of these when one of the solenoid failed on mine. Only swapped the solenoid over to fix the problem.
Posted: Mon Feb 17, 2020 4:33 pm
by Jtb-rs6
Hi
In the middle of strip down to do these as one failed
Are the part numbers 077 109 088p right and 077 109 087p left???
I’ve found them both in auto doc but it’s saying they’re not compatible with the rs6 but or numbers are the same
Posted: Mon Feb 17, 2020 4:43 pm
by Shoppinit
That's what the parts catalogue says....
https://audi.7zap.com/en/rdw/audi+rs6+r ... 109010/#30
Posted: Mon Feb 17, 2020 4:55 pm
by Jtb-rs6
Yup I have thy too 👍
Posted: Mon Feb 17, 2020 5:27 pm
by Mɐʇʇ
I ignore their compatibility lookup mostly and just use the OE part number as my cross check.
Hi
Posted: Mon Feb 17, 2020 8:43 pm
by Jtb-rs6
Brill, thanks guys
Ordered both sides for under £500 on app 👍
Posted: Tue Nov 03, 2020 10:18 pm
by Classik
I was just about pulling the trigger on these, but Autodoc says it's not compatible with the RS6, just the 340HP S6... I suppose I shouldn't care, right? Ta
Posted: Tue Nov 03, 2020 10:29 pm
by Mɐʇʇ
Cross reference the part numbers and I think you’ll see all is fine.
Posted: Mon Aug 28, 2023 10:27 am
by Mr Footlong
Bringing this back from the dead, any idea how many miles you have put on these now Matt and any hiccups with them? The lump is being pulled out of my old girl (finally!) and these sound like a sensible part to swap out at the same time (90k miles).
Posted: Mon Aug 28, 2023 10:40 am
by Mɐʇʇ
No idea how many miles, but they’re still in and still fine. :)
Posted: Mon Aug 28, 2023 10:44 am
by Mr Footlong
Kewl, I'll get a pair of these slapped in, thanks.
Posted: Sun May 25, 2025 4:11 pm
by 2014audis8
How difficult was it to replace just the guide? I bought a new tensioner and was thinking of just pulling the new top guide off and replacing my broken top guide.
