HELP NEEDED ON FRONT BRAKES
Posted: Tue Nov 05, 2019 9:14 pm
by Frazz82
Please can someone help me with this. I ve gone to replace my front pads but the pin that holds the pads in is seized solid. Where is best to get a new one as i am going to destroy this one getting it out.
Re: HELP NEEDED ON FRONT BRAKES
Posted: Tue Nov 05, 2019 9:45 pm
by Scotia
Hi not sure where you can get new pins from but if it’s just to get you moving and get the job done it’s only a couple of bolts at the rear of the Cali per 21 mm bolts I think and you can remove pads and Caliper together from the disc and remove pads from the caliper and get the job done , as long as the pins are not badly damaged should be safe in position as they are .
Hope this helps.
Posted: Tue Nov 05, 2019 10:10 pm
by Ajc
I'm sure euro arse parts do a pin kit .
Posted: Tue Nov 05, 2019 10:18 pm
by Shoppinit
^wot ‘e sed.
Posted: Tue Nov 05, 2019 11:51 pm
by Matt58
Brings back some horrible memories, I changed al discs and pads a few months back, my pins were seized solid, I sprayed loads of penatrating oil on and left to soak, tried several punches twisting, cutting and turning and still nothing, drilled them out in the end, 1.5 hour job turned into all day. Got pin/spring set from eBay
Posted: Tue Nov 05, 2019 11:55 pm
by Frazz82
Cheers fella's. I removed the allen key bolts and changed the pads that way.
Thanks for your help.
Posted: Tue Nov 05, 2019 11:59 pm
by Mɐʇʇ
I'm just having mine completely remanufactured. It aint cheep, but I wanted a proper job.
I'll post a pic once they're back - they looked a lot like that when I sent them out.
Posted: Thu Nov 07, 2019 12:50 pm
by ian_rs6avant
MattV8 wrote: ↑Tue Nov 05, 2019 11:59 pm
were you sent yours mate as i'm looking at sending mine!
Posted: Fri Nov 08, 2019 1:01 am
by Mɐʇʇ
Sent them to BCS - see my other post for pics.
