Throttle Pedal Vibe
Posted: Thu Oct 17, 2019 12:22 pm
by Mɐʇʇ
"They all do that sir".
I'm not up for pulling the dash out - but while the engine's out, can I get the throttle pedal out and rebush it or is the only realistic option the cable ties to take up the slack route?
I'm probably not up for pulling the whole dash out just to do that.
Re: Throttle Pedal Vibe
Posted: Thu Oct 17, 2019 1:22 pm
by Foxmeister
As far as i know, its the brake pedal that gives the issue, and from what i gathered when looking into it, havent seen anything about taking the dash out to do it though, i could be wrong but hopefully it can be done in situ as mine needs done soon also
Posted: Thu Oct 17, 2019 1:36 pm
by Mɐʇʇ
I mean this :
viewtopic.php?f=2&t=109642
But do we mean brake or throttle? I'm now not sure.
Posted: Thu Oct 17, 2019 4:57 pm
by srichards
Vibration on crap roads comes through the accelerator on mine. It's annoying. It may also be felt through the brake pedal as well but I don't notice it as much.
Posted: Thu Oct 17, 2019 6:24 pm
by chunky79
It's the brake pedal bush that wears. Grizz said it's awkward to do, but he used to get new bushes and do them. Doubt it's a dash out jobby, just the pedal box.
Posted: Thu Oct 17, 2019 6:46 pm
by Daveperc
MRC used to fix the problem with a couple of decent cable ties - can't recall what they fixed it to, though there used to be some pics on here I think.
Easy enough job... if you are a contortionist!
Dave
Posted: Thu Oct 17, 2019 10:14 pm
by G pat
I fixed mine with cable ties about 3 years ago, it takes about 10 minutes to do and work very well.
Posted: Thu Oct 17, 2019 11:14 pm
by Mɐʇʇ
Yeah, it sounds like the cable tie fix is the way to go. From Griss' post years ago, he custom made some replacement bushes - imagine those are long gone.
Posted: Fri Oct 18, 2019 2:54 am
by Foxmeister
srichards wrote: ↑Thu Oct 17, 2019 4:57 pm
Im the opposite, i get it more through the brake pedal but can still feel it in the accelerator also, assume they are probably linked by mounting in some way and feel it through both as such
I'll be looking to do cable tie fix, metal probably, and see how that holds up first
Posted: Fri Oct 18, 2019 8:07 am
by Mɐʇʇ
Actually, I wouldn’t metal cable tie it.
Nylon cable ties are self lubricating, hence nylon often used for bushes.
Posted: Sat Oct 19, 2019 5:34 am
by Foxmeister
MattV8 wrote: ↑Fri Oct 18, 2019 8:07 am
Good point, metal could cause corrosion issues further down the line also and i'll have plastic ones lying about, cheap fix
