WHAT OIL IN GEARBOX AND FRONT DRIVE END
Posted: Thu Feb 07, 2019 2:46 pm
by Mumbbles
Hi all
i have a small leak in the output shaft on the rear of the gearbox and the oil that come out when removing the seal was red?
but the when removing the atf lines the take engine out it look like 75w90 oil.
i have spoken to audi main delaler and has given me some part numbers
but my question is audi say that 75w90 LONG LIFE is on the drive end and the atf is in the gearbox main but going on the color of the oil that has come out it looks
like the other way round
can anyone advise please
Re: WHAT OIL IN GEARBOX AND FRONT DRIVE END
Posted: Thu Feb 07, 2019 3:00 pm
by Shoppinit
There should not be red ATF in the transfer box. IF there is then either 1) somebody but the wrong stuff in last time or 2) the ATF is leaking from the box into the transfer box.
The oil in the transfer boxes and diffs is Gear oil SAE 75 W90 (synthetic oil).
/in fact the ATF shouldn't be red at all in the RS6 transmission. It's not OE ATF in that case.
Posted: Thu Feb 07, 2019 3:12 pm
by Mumbbles
the only seal leaking is the output shaft seal on back of gearbox but defo red oil when removed seal and on the atf lines from gearbox is yellow
but had car for 5 years now and had no problems with gearbox running smooth except seal of course
Posted: Thu Feb 07, 2019 3:27 pm
by Shoppinit
Ah OK, I misunderstood.
That's a good sign that the ATF is yellow in the gearbox. The OE stuff is yellowy.
Put the 75W90 in the transfer box and all should be good. Takes a bit less than a litre if memory serves.
Posted: Thu Feb 07, 2019 3:29 pm
by Mumbbles
ok not the atf red stuff then.drain out old oil then refill with 75w90 long life correct
Posted: Thu Feb 07, 2019 3:37 pm
by Mumbbles
just had a thought could be Redline 75w-90 GL-5 which is red in color
by Shoppinit
Yup. In the transfer box. The fill plug is on the top right. You can get to it without removing anything else... just. You'll need a syringe with a tube to fill it, though.
by Shoppinit
No way of knowing. Either way, drain it and get some new stuff in.
Posted: Thu Feb 07, 2019 3:42 pm
by Mumbbles
will do thanks for the reply.
hopefully back on road Monday after new turbos again! and de-cat exhaust and cam cover leak done
if any one is after the rear output shaft seal its been a real nightmare to find a company in the eu that sells it but managed to get one from Poland
Posted: Thu Feb 07, 2019 3:43 pm
by Mumbbles
ZF5HP19,ZF5HP19FLA,ZF4HP20,0734310316
Posted: Thu Feb 07, 2019 3:44 pm
by Shoppinit
Why didn't you get one from Audi? Wasn't particularly expensive last time I bought one.
Posted: Thu Feb 07, 2019 3:54 pm
by Mumbbles
they could not find the part on the system and had to take part down to them and they matched it up and was £38 +vat and would have taken 4 weeks according to camberly Audi
but needed sooner like most things in life so went on the hunt as the orignal seal was made by zf with no audi part number on it and managed to get it for £17inc postage and was OEM from zf
Posted: Thu Feb 07, 2019 3:56 pm
by Shoppinit
Nice. Poor showing from Audi there. Imagine my surprise.
Posted: Fri Feb 08, 2019 6:42 pm
by bilko1
My oil seal was £10 from Audi a few years back, they did mention that there was an updated seal and output flange though which I declined.
