Seized Crankshaft
Posted: Mon Sep 17, 2018 11:49 am
Morning all
Just after some input from folk who may have experienced similar symptoms to the below.
My car (2004/106K) is currently poorly. The vehicle has been well maintained and recently had the timing belt etc done as part of a major overhaul. This was a few months ago and has been running fine. That was until a couple of weeks ago.
While driving at circa 0mph to 20mph in Friday rush hour traffic the car started misbehaving and had symptoms that I would describe as similar to a coil pack failure. It wasn’t running right but no warning lights or concern on the dials. I travelled circa 20m or so and turned off the engine, with the plan of switching it back on to see if this was simply a gremlin. Unfortunately the car then refused to start.
The car has gone back to the Audi specialist who did the timing belt work and his initial findings were that the belt felt slack when he squeezed his hand through and the crank pulley was seized. Given the potential for a tensioner failure I contacted Audi UK and they remain interested in the issue. However now the specialist has advised that having stripped the front down, the timing belt itself is not slack.
The oil has been drained and there are no signs of swarf although I’ve requested that the sump is removed to make sure. The only other symptom that is worth mentioning is when I was attempting to start the car, not knowing the crank shaft was seized, the car made zero noise when turning the ignition and the battery gauge dipped, almost as if the alternator was the issue.
Mechanically the gearbox has been fine and had the ATF oil and filter done at the same time as the timing belt. I have recently had the F125 switch diagnosed and this was on order to be replaced. Unfortunately the car visited the garage before the part arrived!
Any thoughts or shared experiences please? Happy to answer any pertinent questions!
