Page 1 of 2
Car won’t boost more than 5 psi, boost leak?
Posted: Tue May 29, 2018 9:26 pm
by 8520
Scanned with Vag Com, no codes but the car won’t boost past 5 psi. Requested boost versus actual boost is way off.
Do I have a boost leak somewhere? I’ve already checked intercooler hoses and swapped the n75 out with a spare.
Car is 034 chipped and I have Wagner ic’s.
Re: Car won’t boost more than 5 psi, boost leak?
Posted: Tue May 29, 2018 10:38 pm
by Shoppinit
What are your MAFs reading?
And your trim values?
Pull your DVs off and test them (suck test).
Posted: Tue May 29, 2018 10:51 pm
by 8520
Shoppinit wrote:What are your MAFs reading?
Had already swapped dv’s. Forgot to mention that.
I’ll try to get those other readings tonight.
Posted: Wed May 30, 2018 3:44 am
by paulyang39
Recently i just check my Intercooler and noticed the oil at the edge on both of my intercooler,
and i pressure test them, they are absolutely leaking~~
since this is very easy to check, you can check this area too when you got time.
Posted: Wed May 30, 2018 8:58 am
by bam_bam
Pull your DVs off and test them...
Isn't this a wank test?
Posted: Wed May 30, 2018 9:38 am
by MeTsU
I'm not familiar with this method - would you mind explaining in great detail?
Posted: Wed May 30, 2018 10:49 am
by bam_bam
Well... when you suck your DV off it's a blowjob. When you pull your DV off, it's the wank test.
Posted: Wed May 30, 2018 11:47 am
by MeTsU
Ah, sounds like one could really enjoy this. I'll have to give it a go.
Posted: Sat Jun 02, 2018 11:14 pm
by Shoppinit
You make any progress on this?
Posted: Wed Jun 06, 2018 5:17 pm
by 8520
Shoppinit wrote:You make any progress on this?
Sorry, but no. Suspension issues were a bit more pressing due to bad drc and upper control arms. Got in to that last night, and needless to say I will never buy a car that isn’t from the west coast again. Frozen pinch bolts on both sides.
Posted: Wed Jun 06, 2018 5:25 pm
by Shoppinit
Wish they all could be Californian, eh?
Posted: Wed Jun 06, 2018 10:16 pm
by 8520
Shoppinit wrote:Wish they all could be Californian, eh?
I live near Seattle so I’m not used to dealing with corrosion at all Image
Posted: Mon Jun 11, 2018 5:00 pm
by 8520
Success.
Posted: Mon Jun 11, 2018 5:54 pm
by Mɐʇʇ
Nicknamed the bastard bolt for a good reason.
Posted: Wed Jun 13, 2018 11:24 am
by PipRS6
Every car has a bolt that takes on the name of bastard bolt.
