Oil leak (1400 troublefree km....)
Posted: Tue Mar 20, 2018 7:46 pm
by Siph3r
Guess i'm finally a true C5 RS6 owner now as the first failure has come.
Well, I sure enjoyed the 1400km since I bought it in January Image
I'm about to get the front lifted to see what has gone south.
Any guesses ?
Drippin on rhs, just a bit in front of the wheel.
Re: Oil leak (1400 troublefree km....)
Posted: Tue Mar 20, 2018 8:37 pm
by Shoppinit
Oil cooler and/or pipes.
Posted: Tue Mar 20, 2018 8:42 pm
by Gregstv
Check around the oil filter.
Posted: Tue Mar 20, 2018 8:48 pm
by Siph3r
Mhm... I have read about this horror story previously.. From picture the leak is in the connector on the oil lines. Is this where it usually leaks? I was under the impression that the leak often was on the fitting into the cooler it self(?)
I guess the leak is on the oil line and not the pipe it's connected to?
Big question is now..
How rapidly does this worsen?
Leaving for Easter vacation with the family on Friday with the car(that was the plan)
I do NOT want to drive my wife's 1.8TQ packed with kids and luggage and the S8 just blew an oil leak in the steering rack Image
What to do ImageImage
Posted: Tue Mar 20, 2018 9:14 pm
by Shoppinit
You've gotta ask yourself one question: "Do I feel lucky?" Well, do ya, punk?
Posted: Tue Mar 20, 2018 9:51 pm
by Siph3r
Always!
Does anyone know if the the line and pipe connector is ok to dismantle, or will this lead to the same as when removing the line from the cooler itself,destroying the threads?
If disconnecting is doable, should it not be an "easy fix" to cut the line, lenghten it AN connector an some line an find a suitable fitting to match the oil pipe? or is that some special Audi-Rs-nothing-else-matches kinda thing?
Posted: Tue Mar 20, 2018 10:47 pm
by Siph3r
just another question after checking Etka for some more info... This cooler, does it also cool the gearoil? is it a combined unit for both engine and gearbox with separate chambers?
Please tell me i'm wrong here..
Posted: Tue Mar 20, 2018 10:54 pm
by Shoppinit
Yes, it's a combined engine oil and ATF cooler / heat exchanger.
Posted: Tue Mar 20, 2018 11:07 pm
by Siph3r
Appreciated Shop.
And the upper lines are for the ATF an the lower ones for engine oil?
Posted: Tue Mar 20, 2018 11:31 pm
by Shoppinit
ATF at the top, engine oil at the bottom according to the training manual.
Posted: Wed Mar 21, 2018 7:56 pm
by Mɐʇʇ
Just replied to you. Classic place they fail - just replace with Teflon stainless hose and self assembly fittings as per my DIY.
Posted: Mon Dec 21, 2020 6:07 pm
by tuningservice
do you have any pics for your fix? you know what threads it is on the cooler itself'?
Posted: Mon Dec 21, 2020 6:10 pm
by Mɐʇʇ
Yup. See here.
Posted: Mon Dec 21, 2020 6:30 pm
by tuningservice
Yup. See here.
aha, so m22/1,5 on the cooler as well?
