Headlamp Bulbs
Posted: Thu Jan 12, 2017 9:40 pm
by JimRS6
Guys,
Which bulbs do I need to replace the xenons? I've got one dipped failing - it's taking ages to come on, and repeated main beam on/off cycles(Pass side)
I popped into Halfrauds and they wanted silly money, and couldn't distinguish the RS6 between an A6 on their system.
Re: Headlamp Bulbs
Posted: Thu Jan 12, 2017 11:04 pm
by Mɐʇʇ
Euro car parts list some osram ones for 40 quid.
I'd also replace both at the same time - the colour of them changes over time so it'll probably look odd if you only replace one.
They've got a sale on...although their sales seem to be a bit like sofa wholesalers - but that brings the price down to 30 quid each.
Re: Headlamp Bulbs
Posted: Fri Jan 13, 2017 9:19 am
by simonpoulton
Is it definitely the bulb? They have the high voltage ballasts can also fail so might be worth swapping the bulbs from left to right etc and seeing if the problem persists.
Re: Headlamp Bulbs
Posted: Fri Jan 13, 2017 11:11 am
by JimRS6
It's still currently working -just
But cheers I will check the ballasts, can't imagine they are cheap to replace.
I have got one bulb that isn't as 'blue' as the other, although it's the one that is coming on fine.
Will get the bonnet open and have a look later.
Thanks Guys
Re: Headlamp Bulbs
Posted: Fri Jan 13, 2017 11:32 am
by simonpoulton
You probably already know this but they work on really high voltage. Best make sure they are off first before fiddling!
Re: Headlamp Bulbs
Posted: Fri Jan 20, 2017 9:57 pm
by JimRS6
Update: tried the drivers side bulb in the place of the one that isn't working properly, and it worked, so its bulb and not ballast
Re: Headlamp Bulbs
Posted: Sat Jan 21, 2017 4:10 am
by nene
I replaced mine with 5400K Osram Xenarc. They were slightly better white than the stock 4300K. They have been great and working for many years now. Hope I did not jinx myself.
