Locking and unlocking
Posted: Thu Nov 24, 2016 12:08 am
by Chris6
Hi guys I've owned my rs6 for a year now and been meaning to ask this question but keep forgetting. To unlock the car I have to press the button on my fob 4 times. It's the same with locking it if the car is left open for a while. If I lock then unlock it does it first go. Only does it if left for half an hour or more. Surely this isn't normal?
Chris
Re: Locking and unlocking
Posted: Thu Nov 24, 2016 11:05 am
by Shoppinit
Doesn't sound normal. You'll need a Vagcom to diagnose properly. You could try changing the batteries and re-learning the fobs, but if you can't relearn them for some reason then you'll be in a more awkward position.
Does the spare key do the same?
Posted: Thu Nov 24, 2016 11:25 am
by HPsauce
Had similar problems on another car (not an Audi) and it was down to a combination of poor-quality batteries and dirty contacts inside the fob.
So, for starters, fit new batteries and ensure the contacts are firm and clean, abrade slightly if necessary.
Posted: Thu Nov 24, 2016 11:42 am
by Ajc
The problem with second hand electrical parts , certainly when they are a very common fault like the door locks on vag cars is that even if it does cure the problem it's bound to rear it's head again shortly after .specially if it's from again vehicle of the same age and haven't been change my previously. You can get copy versions off ebay for not bad money though I have replaced 2 drivers side eBay units in under a year for different faults on mine
*wrong thread * bugger . :bash:
Posted: Fri Nov 25, 2016 12:53 am
by Chris6
Yeh it does it with both fobs. If I for example go to the petrol station. It locks and unlocks first time. It's only when it's been left for a while the fob has to be pressed 4 times. Always 4 times.
Posted: Fri Nov 25, 2016 7:53 am
by chunky79
Sounds like your car is suffering with OCD.
Posted: Fri Nov 25, 2016 9:24 am
by Ajc
Is it worth checking the bcm for any water ingress ?
Posted: Fri Nov 25, 2016 9:52 am
by Shoppinit
It's a weird one. Try recoding the central locking module.
Posted: Fri Nov 25, 2016 11:08 am
by Nobby
Ajc wrote:Is it worth checking the bcm for any water ingress ?
*CCM
Is there a specific antenna for the central locking or is in inside the CCM unit? I know there are specific antennas for other models (sometimes in the rear wings or above the boot lid). Certainly newer keyless models have an antenna too.
Posted: Fri Nov 25, 2016 11:17 am
by mikep99
is it actually trying to unlock the 3 times before the 4th successful try - ie. can you hear any of the locks trying to do anything?
Mine used to unlock only on the second attempt quite regularly - then the boot lock failed, replaced it and its been fine since..
Mike
Posted: Fri Nov 25, 2016 11:17 pm
by Chris6
chunky79 wrote:Sounds like your car is suffering with OCD.
I think you are right! Haha
No the first 3 times it does nothing at all.
How do I go about recoding it?
Posted: Fri Nov 25, 2016 11:49 pm
by Nobby
It's quite simple if you have VCDS - see below. I think you can also do it with just the keys and ignition by I've never tried it.
http://www.ross-tech.com/vag-com/cars/v ... ching.html
Posted: Sat Nov 26, 2016 11:15 am
by TechNick
This looks like the key/ignition method, but haven't had to use it for a while. Looks familiar.
You'll obviously need 2 keys for this, though.
https://youtu.be/lb0UdmAVmz4
