ABS module failure? VCDS codes attached
Posted: Fri Aug 19, 2016 10:58 am
Hi All
I'm reaching the conclusion my ABS module is toast and would appreciate any ideas on anything else I could check before booking her in.
Symptoms - for the last few weeks I have been getting the ESP warning light or ABS light illuminated (never both at the same time). Typically when I start the car no warning lights are displayed, then after a few miles the ESP light comes on and after another few miles it will go out but be replaced by the ABS light or vice versa. Turning the ignition off usually clears this.
I've also noticed that the car feels down on power when the ABS light is on but fine when the ESP light is on/no lights are on. So far I've fitted a new brake switch, cleared codes and scanned again, the codes below have been returned. I should add that when I tried reading module 03 ABS when the ABS light was on last night it could not see the controller, but when I've scanned with no lights or ESP only it can.
A few questions:
1. I'm going to try cleaning the ABS module and yaw sensor contacts- is the yaw sensor under the rear seats (avant)?
2. Can I pull the ABS fuse and drive the car without it?
3. Has anybody used http://www.ecutesting.com to rebuild their ABS module or recommend a similar company?
TIA
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,06,08,15,16,17,18,22,34,35,36,37,45,55,56,57,65,67,75,76,77
Address 01: Engine Labels: 077-907-558-BCY.LBL
Controller: 4D1 907 558
Component: 4.2l V8/5VT G 0002
Coding: 0010752
Shop #: WSC 66565
VCID: EBA9C4AF8A9D
3 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 008 - Implausible Signal - Intermittent
16502 - Shareware Version. To Decode all DTCs
P0118 - 002 - Please Register/Activate - Intermittent
16955 - Shareware Version. To Decode all DTCs
P0571 - 008 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 4B0 927 156 FB
Component: AG5 01L 4.2l5VT RdW 1315
Coding: 00001
Shop #: WSC 00000
VCID: 6CAB47B30F93
1 Fault Found:
17087 - Brake Switch (F): Electrical Malfunction
P0703 - 35-10 - - - Intermittent
Address 03: ABS Brakes Labels: 4B0-614-517.LBL
Controller: 4B0 614 517 AD
Component: ESP 5.7 RS 6 2310
Coding: 06697
Shop #: WSC 02195
VCID: 63B92C8FE24D
2 Faults Found:
01425 - Yaw Rate Sensor (G202); Signal Wire
57-10 - Electric Circuit Failure - Intermittent
18256 - Shareware Version. To Decode all DTCs
P1848 - 35-10 - Please Register/Activate - Intermittent
A few questions:
TIA
Coding: 0010752
Shop #: WSC 66565
VCID: EBA9C4AF8A9D
3 Faults Found:
Coding: 00001
Shop #: WSC 00000
VCID: 6CAB47B30F93
1 Fault Found:
Coding: 06697
Shop #: WSC 02195
VCID: 63B92C8FE24D
2 Faults Found:
