Switched 12V in the rear?
Posted: Sun Mar 27, 2016 11:00 am
by MarkPRS6
Hi all and Happy Easter
I'm fitting a rear view camera to the back of my Avant and I need a switched 12 volts. I really don't want to wire directly to the battery as tempting as that is.
I'm assuming that there must be a switched supply for the stereo but just wondering if there is something a little easier to access?
Mark
Re: Switched 12V in the rear?
Posted: Sun Mar 27, 2016 12:38 pm
by Jultsu
MarkPRS6 wrote:Hi all and Happy Easter
Mark
Reversing lamp(s) ?
Posted: Sun Mar 27, 2016 2:39 pm
by Shoppinit
There's a cigar lighter in the boot. Switched I believe.
Posted: Mon Mar 28, 2016 4:38 pm
by chunky79
Don't you just want it for reversing? If so, go off the relay.
Posted: Mon Mar 28, 2016 10:08 pm
by MikeFish
I wanted to avoid the switch on flicker when selecting reverse with the rear view camera i futted in mt 4 so I avoided using the reverse light feed.
I took a feed from the Bose amp supply in the boot. It is not truely switched as it stays active for about 30 seconds after you lock the car or up to 30 mins after you switch igintion off if you don't lock the car. Doesn't the 6 have an amp in the side panels of the boot too?
Posted: Mon Mar 28, 2016 10:44 pm
by Nobby
Shoppinit wrote:There's a cigar lighter in the boot. Switched I believe.
Pretty sure they are permanently on - used it for a fridge while camping at Silverstone last year.
Posted: Fri Apr 01, 2016 8:24 pm
by MalcolmSu
reallly? just two in the passenger compartment in mine (saloon)...
Posted: Fri Apr 01, 2016 8:49 pm
by ahoooga
OP has an Avant Malc according to the first post. Avant has a socket in the 'boot' part
Posted: Fri Apr 01, 2016 8:53 pm
by MalcolmSu
Ah, another reason why Avants sell for more...
