Central locking problem
Posted: Thu Jan 28, 2016 10:01 pm
Hello folks,
Got a problem with my central locking.
It's not working remotely off the key and when I turn the key in the drivers door it only opens the drivers door. You can only get the others to open by resetting from battery or convienience module.
Was intermittent at first but is now constant. Checked the convenience module, and although it's wet around it (normal leak), it's totally intact and shows no signs of damage. Also got no problems with Windows etc
I thought it was the key at first but got it on the bench and can tell its outputting a signal. Got a new key made and that doesn't work remotely either.
So I'm thinking there's 2 things I should look at;
1 the Rf receiver for the locking - I was thinking it might be in the roof where the GPS receiver is. does anyone know where it is?
2. Does anyone know if the dead locking can be turned off through Vagcom so when I open the door with the key all doors open?
Cheers,
Cheers,
