Name that noise!
Posted: Wed Sep 02, 2015 4:49 pm
by Rstoney
I've been trying to track down the source of this noise. Only does it when the car is on the ground. Also only used to happen when coming to/from a stop, now happens even when turning the wheel at a standstill. Only happens on the O/S/F wheel. Here is a little clip I have made.
https://youtu.be/xZT0XAeZpa8
Any ideas?
Re: Name that noise!
Posted: Wed Sep 02, 2015 5:16 pm
by Shoppinit
Sounds like a ball joint sticking. Maybe slightly loose steering rack.
Posted: Wed Sep 02, 2015 9:11 pm
by Rstoney
I checked the steering rack bolts and they were all tight. Then I whipped the wheel off to have a poke about...turns out when I asked someone to replace all the control arms and tie rod ends,they forgot about the tie rod part. Pretty sure that could be the cause. Bit pissed off. There's a reason I like everything replaced at the same time. Need the car for holiday dog transport on Friday, so I'll have to get someone to do it quick tomorrow!
Posted: Mon Sep 21, 2015 7:28 pm
by carterjohn
I had the same problem and I replaced all the arms then I ended up replacing the knuckle and that got rid of the noise..
https://www.youtube.com/watch?v=dkzx3AI ... e=youtu.be
