Variable boost controller
Posted: Thu Aug 06, 2015 9:36 am
by MarkPRS6
Bit of a long shot, but has anyone fitted a variable boost controller to their RS6. I appreciate that the max boost will be limited by the ECU, but just wondered (a) if anyone has done it and (b) if it makes any real difference to the performance.
Re: Variable boost controller
Posted: Thu Aug 06, 2015 1:30 pm
by bam_bam
What's wrong with just using the accelerator pedal?
Posted: Thu Aug 06, 2015 2:23 pm
by Mɐʇʇ
It already has a boost controller valve, controlled by the ECU. I absolutely would not override this. If you want more power, use a different map. If you want less, put your foot down less. Doing anything else will cause problems since the ECU decides how much boost to request, then measures how much is being achieved. If the 2 differ too much, it'll raise an error.
Posted: Thu Aug 06, 2015 7:21 pm
by C_J
No and no.
That is all.
Posted: Thu Aug 06, 2015 9:18 pm
by bigben143
variable boost controllers = no boost control, a custom remap is cheaper then a engine pull for new turbos!
Posted: Thu Aug 06, 2015 9:40 pm
by Shoppinit
Suitably flamed now?
Posted: Fri Aug 07, 2015 1:04 am
by sweegie
Multi-map switching is the best way to achieve this.
Posted: Fri Aug 07, 2015 2:10 am
by bam_bam
Shoppinit wrote:Suitably flamed now?
Yes, I think it's fair to say he's cooking with gas.
