Page 1 of 3
Topping up rear output shaft oil.
Posted: Wed Nov 26, 2014 4:00 pm
by mavada
My car is in for its mot this friday, so would be a good idea to top up the rear output shaft oil (75W90 full Synthtic) when its on a bridge.
Anyone got a pic from where to drain it and location to put new oil in?
Unfortunately i dont have access to my Elsawin...
Cheers,
Mark
Re: Topping up rear output shaft oil.
Posted: Wed Nov 26, 2014 4:08 pm
by pete62
Is this what you want?
Sorry if it's a bit blurred
Posted: Wed Nov 26, 2014 4:20 pm
by mavada
Thanks alot :thumbs:
Looking at it, got me thinking if this pic is the from the rear part of the gearbox, cos thats the one i need...
Posted: Wed Nov 26, 2014 6:39 pm
by Shoppinit
That's the rear diff, not the transfer box which is the one I believe you are talking about, Mav.
I did this the other day on mine. It's easy.
You just need to get the car in the air (I used ramps on the front and axle stands on the rear to get the car level) then crack the fill bolt. This is a bugger, but you can just get to it with a socket. It's angled in such a way that you can just miss the exhausts to get the bit in the bolt head. Mine was on very tight. Be careful not to burr the head of the bolt or you'll be in a world of hurt.
Posted: Wed Nov 26, 2014 6:43 pm
by mavada
Thanks Ben,
Is it worth it to drain the old oil first or just top it up?
Posted: Wed Nov 26, 2014 6:46 pm
by Shoppinit
I just topped mine up. It took about 300ml IIRC.
Get a big syringe with a tube on it to fill it up.
Posted: Wed Nov 26, 2014 6:50 pm
by mavada
...is it obvious which plug it is/they are?
Posted: Wed Nov 26, 2014 7:07 pm
by Shoppinit
Yes. Look at the ETKA diagram and you will recognise the plug.
Posted: Wed Nov 26, 2014 8:25 pm
by mavada
:thumbs:
Posted: Wed Nov 26, 2014 9:58 pm
by Nobby
I did mine not too long ago when I changed the seal. I've got a little 1ltr bottle with a pump and it makes things very easy - used it in my gearbox oil change too.
Posted: Wed Nov 26, 2014 10:13 pm
by mavada
Nobby wrote:I did mine not too long ago when I changed the seal. I've got a little 1ltr bottle with a pump and it makes things very easy - used it in my gearbox oil change too.
...i hope the mot shop has one...im bringing my own oil.
Posted: Wed Nov 26, 2014 10:49 pm
by pete62
Hopefully these are the right pages?
Posted: Wed Nov 26, 2014 11:16 pm
by mavada
...i think thats the front right diff side...
Posted: Wed Nov 26, 2014 11:19 pm
by pete62
Bugger :bash:
Posted: Thu Nov 27, 2014 8:08 am
by mavada
No worries, thanks for the effort :thumbs:
