Page 1 of 2
Engine mounts
Posted: Thu Jul 24, 2014 1:34 pm
by taspland
one of my engine mounts is bringing up an error, so i want to replace both of them, however Audi do not have any in stock for this country or in europe.
does anyone know if i can get this part elsewhere?
Re: Engine mounts
Posted: Thu Jul 24, 2014 2:24 pm
by mik15
try ecstuning in the States...
Re: Engine mounts
Posted: Thu Jul 24, 2014 7:01 pm
by Heardy
Ive just bought a replacement offside one for mine from Tps, it came the day after i'd ordered it
Re: Engine mounts
Posted: Thu Jul 24, 2014 10:20 pm
by taspland
Do you have a contact number for them? Are they In slough ?
Re: Engine mounts
Posted: Fri Jul 25, 2014 10:58 am
by taspland
Spoke to TPS, Same as Audi, none in Country, on back order looking at at least 6 week wait
might have to buy from the US or aftermarket
Re: Engine mounts
Posted: Fri Jul 25, 2014 11:49 am
by Shoppinit
Just live with it until it arrives. It's not a vital part.
Re: Engine mounts
Posted: Fri Jul 25, 2014 3:52 pm
by taspland
Yeah i guess so, just the engine management light is annoying me
Re: Engine mounts
Posted: Mon Jul 28, 2014 1:04 am
by sweegie
Engine mount faults won't cause the check emgine warning light - must be something else if its lit....
Re: Engine mounts
Posted: Mon Jul 28, 2014 7:57 am
by longman h
So which error code is being thrown for the mount?
Re: Engine mounts
Posted: Mon Jul 28, 2014 10:49 am
by taspland
These are the codes i'm getting
VCDS-Lite Version: Release 1.2
Monday, 28 July 2014, 10:48:38.
Control Module Part Number: 4D1 907 558
Component and/or Version: 4.2l V8/5VT G 0004
Software Coding: 0010752
Work
Shop Code: WSC 00000
VCID: EBA9C4AF8A9D
3 Faults Found:
17983 - Right Engine Mount Solenoid Valve (N145): Short to Plus
P1575 - 001 - Upper Limit Exceeded
17963 - Shareware Version. To Decode all DTCs
P1555 - 001 - Please Register/Activate - Intermittent
16395 - Shareware Version. To Decode all DTCs
P0011 - 002 - Please Register/Activate
Re: Engine mounts
Posted: Mon Jul 28, 2014 11:27 am
by Shoppinit
Um, the other codes are much higher priority. Overboost and cam timing. Don't remember seeing that 16395 before. You trailblazer...
Re: Engine mounts
Posted: Mon Jul 28, 2014 11:49 am
by taspland
I have just recently had the Cambelt repalced and new water pump and all new vacuum hoses, as they old ones were split, I called the garage they are going to look at it tomorrow as they think the the timing message is being brought up due to the vacuum message.
Re: Engine mounts
Posted: Mon Jul 28, 2014 11:59 am
by Shoppinit
It's not. More likely they didn't do the cambelt right.
They probably put the N75 plumbing back together wrong, or the DVs which is giving the overboost. How does it drive? You should be losing power.
Get your
Vagcom registered, or find someone with one, and log your dephasing values and boost.
I'm betting they didn't use the right tools to do the cambelt and it's a tippex special.
Where are you based?
Re: Engine mounts
Posted: Mon Jul 28, 2014 12:36 pm
by taspland
I'm based in High Wycombe area
and it actually drives really well, not noticed any loss of power, i'm hoping it is just the N75 plumbing
and yes i need to get my
Vagcom registered that's something i've been meaning to look into as it would be usefull
Re: Engine mounts
Posted: Mon Jul 28, 2014 12:40 pm
by Nobby
If you ever want to come to Bicester you can use my
VCDS
