Anyone removed the stock exhaust backboxes?
Posted: Mon Jun 23, 2014 2:34 pm
Howdo all, has anyone here either removed the stock exhaust backboxes or got no silencers at all and has any vids or recommendations?
Reason - I'm doing quite a few car events/meets/trips etc over the summer (pretty much 1-2 a week) and the stock exhaust is just too quiet so what I'd like to do is remove the backboxes to unleash more V8/turbo noise (no extra power I realise) and fit a straight through pipe from just behind the resonators (keeping them to reduce drone at motorway speeds). However, as this is my daily driver I want this to be reversible so I will sleeve the remaining stock exhaust allowing me to swap between either the stock backboxes or the straight through pipes depending on what I'm doing i.e backboxes for mon-fri (and when selling) and then straight through for sat-sun when doing trips.
At present it has stock downpipes with the Cats and Pre-Cats so as this mod is after the lambda's and the diameter isn't changing then I shouldn't need it remapping nor should I gain/lose any torque/power, I hope.
My preferred option would be to fit a milltek full non-res exhaust inc Decat for the sat-sun noise but (and this is a heinous crime I know) I'd want it valved to bring it back to OEM noise levels for mon-fri as I find the non-res milltek can drone badly at motorway speeds and before I spend nearly £2000 inc fitting one I fancy trying the £200 option which just requires a little spannering time instead which I always enjoy.
I "should" be getting it done on Wednesday if it's not back at MRC to sort a sticky cam follower and I'll post up some build pics and vids.
Cheers...............................................Ian
