Timing belt change
Posted: Fri Jan 17, 2014 8:53 pm
Evening all.
Today i stripped the front end in order to carry out a timing belt change.
The CONTITECH timing belt at just over fours years use and 30k miles was found in near perfect condition with no visible cracks anywhere. In between the teeth off the belt was almost as good condition as the new genuine Audi DAYCO belt that will be going on tomorrow. I'm sure this belt would last another couple of years no bother but as always just not worth the risk!!!
The water pump which also had fours use use and 30k miles on it was in perfect condition with no play in the bearings, this was the same for the eccentric tensioner and hydraulic tensioner roller. However, the actual hydraulic tensioner itself was solid and unable to compress to get a pin/drill bit in. I applied a fair amount of pressure but gave up in the end in as didn't want to shear it's connecting bolt!!! When i removed it the hydraulic piston extended, but when it was in place it would not compress. I think this is the original hydraulic tensioner with 101k miles on it.
When i set about locking the crank and cams i noticed when the crank was locked in position the camshaft locking bar was slightly out and would not locate. In order for the camshaft bar to fit i rotated the crank ever so slightly until it stopped against it's locking pin. As you can see from the pic the the timing was slightly out. Do you think i'll notice any difference in running once it's all back together with timing spot on??
Any comments much appreciated.
Gordon
Gordon
