RS6 C5 Gearbox issues - Help!
Posted: Thu Dec 05, 2013 5:52 pm
I'm new to the forum, but have had my beloved C5 for 5 years.
It's done just over 100000 miles and has recently developed the dreaded gearbox problems. My symptoms are the car disengaging during acceleration, revs shoot up, then an awful clunk into gear. Its worse once its warmed up, and under more load (uphill, strong acceleration) Its worst 3rd to 4th, but also seems confused 1st to 2nd and back to 1st in slow traffic - the clunk is there but just not as marked as the speed is so slow. 2nd to 3rd and 4th to 5th are still perfect.
TBH, symptoms have been there for a bit of time. It clunked just once a number of months ago, then no more problems for a while. Then did it again and eventually started doing it more often. However, its not doing it all the time and I have learnt how to drive it carefully to minimise the symptoms. Strange thing is its actually got better recently, but I only drive it for 10-15 minutes at once and only very carefully, and I know if I put my foot down, it will jolt into gear again, which tends to bring on the symptoms for another week or so. I don't understand why it's inconsistent and not problematic all the time, or why its got better, and wonder if its more likely an electronic than manual problem.
Obviously the time has come to bite the bullet and get it fixed. I want to sell it once its done, but i want to be able to say to a buyre its genuinely fixed. I've read a lot of the posts already on here about it, and have seen there's various problems it could be, eg just ATF fluid or pipe, or more serious things like torque converter, EGT or Oxygen sensors, valve body. I don't want to pay a fortune to get it fixed if it turns out its just a fluid issue (there is a small oil leak but I can't identify exactly where it is coming from, and come to think of it there was a similar small leak a number of months ago which seemed to clear up without a defintie fix, so i don't know if that may be linked). However, if it needs the full works, I want to get it sorted.
It sounds like Grizz at Unit 20 is top of the list to go to, but any advice, recommendations welcome.
