Error code 18080 p1672 cooling fans staying on C5 RS6
Posted: Mon Nov 25, 2013 3:09 pm
by Aggro65
I hope someone can help. You all have posted helpful answers regarding this cooling fan open to short issue but none have worked. I firstly checked that everything looked OK ie no frayed or cut wires, rusted terminals etc. after reading posts, I changed the main cooling fan control unit, the one that sits under the left longitudinal member. Problem persists. I then changed the green engine coolant temp sensor. Problem persists. I then changed the ECM relay. Problem is still there. The only way I can get power off the fans was when I pulled the ECM relay out, hence my decision to replace it. I'm now thinking that the fan is faulty but this poses 2 problems. 1 it's not available in South Africa, 14- 21 working days to get it here from Germany and 2 they want to rip me off by charging me over 750!pounds for the complete fan and control unit. If this is what I need to do then fine but I'm loathe to spend the money if it doesn't solve the issue
Guys I need help. I don't have experience using the VCDS to measure blocks etc but obviously, if someone can tell me what to do, I will give it a go.
:bash:
Re: Error code 18080 p1672 cooling fans staying on C5 RS6
Posted: Mon Nov 25, 2013 11:12 pm
by Dubbuds
Good luck sounds a headache, maybe try a simple one and disconnect the battery for a couple of hours. Could be and ecu fault. What error codes do you get?
Posted: Mon Nov 25, 2013 11:24 pm
by bilko1
There are 2 fans one is controlled by the module on the chassis leg that you changed the other has the module built in to the fan unit.
Posted: Tue Nov 26, 2013 11:51 am
by Shoppinit
You changed the wrong control module. That code is for the 600W fan that has the control module built into it. Audi should have known that.
Posted: Tue Nov 26, 2013 11:53 am
by Shoppinit
You can use the Vagcom to power up the fans individually by using the output tests and walking through the outputs - they will be labelled, it's pretty straight forward.
But the code is fairly specific. Still, if you've got a Vagcom, do the test.
