Page 1 of 2
Re: Oil pipe leak
Posted: Mon Jun 17, 2013 9:10 pm
by captrs6
Hi Folks,
I have a slight oil leak coming from what I think is the oil coolant pipes.
As part of the repair, I may as well change the oil and filter.
I may get this beast for working more than a week or so...happy bl00dy times.. :boohoo:
Could be close to trade in time...
Capt.
Re: Re: Oil pipe leak
Posted: Mon Jun 17, 2013 9:55 pm
by deanflyer
Just been getting mine replaced, picking it up tomorrow. Beware that there are quite long lead times for the oil cooler pipe s. mines been off the road for 2 weeks.
Re: Oil pipe leak
Posted: Mon Jun 17, 2013 11:37 pm
by sweegie
Grim.
Beware the connections to the radiator side, as mine took a gas axe, brute force and saw to free it :audibash:
I'll always have a go at things first, but that job I would have gladly paid someone else for.
Shan times :thumbsdown:
Posted: Tue Jun 18, 2013 8:18 am
by Shoppinit
You don't say where the leak is. Everyone's assuming the oil / ATF cooler which is where it generally leaks.
Re: Oil pipe leak
Posted: Tue Jun 18, 2013 8:50 am
by captrs6
Hi Sweggie / Shop
Having taken off the plastic protective engine casing, I checked the sump and cleaned all around the undercarriage. The leak is coming from the front right drivers side of the vehicle. There are two stainless steel pipes, that although are slightly corroded, I dont think that is the issue. The leak seems to be higher up and is dripping on to the lower of the pipes...
Hope that makes sense?!?!? - Have to be honest guys - after a £7.5k repair at Unit and replacing the N75, I thought I could at least have drove it..starting to become a right pain in the :assflash:
Capt
Posted: Tue Jun 18, 2013 8:56 am
by Shoppinit
What was the £7.5 repair?
Posted: Tue Jun 18, 2013 9:04 am
by captrs6
Shop - Recon Gearbox
- 4 x Goodyear Eage F1 Tyres
- Intercooler repair
- EGT Sensors
- Parking sensors
- Intercooler Repair
- Engine Mount
- Stage 1 Remap
- CV boots
- EGT Sensors
- Wishbone
- MOT
- KW Coilover Kit.
- loads of other stuff
and a few other wee bits!!
Posted: Tue Jun 18, 2013 9:12 am
by Shoppinit
If the box was changed then the engine will have been out. Could be that something hasn't been tightened up properly or was damaged. Have you spoken to whoever did the job?
Posted: Tue Jun 18, 2013 12:12 pm
by captrs6
Hi Shop - I will speak to Grizz. The leak is coming out at the bottom of the oil cooler (i think)
Posted: Tue Jun 18, 2013 12:52 pm
by mik15
then it might be the oil cooler pipe which is made of plastic, when i had the engine out i've replaced it with the Bufkin one made of aluminum.
Posted: Tue Jun 18, 2013 1:02 pm
by Shoppinit
That's a coolant pipe, though, not an oil pipe.
Posted: Tue Jun 18, 2013 1:06 pm
by mik15
yeap, my bad, i was thinking at something else...
Re: Oil pipe leak
Posted: Tue Jun 18, 2013 3:03 pm
by captrs6
Guys - how easy is it to replace coolant pipes should the need arise? I have the car booked in with an Audi / VAG specialist here in Glasgow?
Posted: Tue Jun 18, 2013 3:09 pm
by Shoppinit
Coolant or oil? Confused...
Re: Oil pipe leak
Posted: Tue Jun 18, 2013 3:10 pm
by captrs6
Sorry Shop - Oil
