Sputter on start up?
Posted: Fri Jan 25, 2013 10:08 am
by Keaney
The last few times I've started the car up from cold it's started fine but seems to sputter a little before putting the revs into the normal high idle.
Vagcom has not revealed anything so I'm just wondering if I should give a little gas on cold mornings or if there's something I should be checking?
Any help appreciated
Re: Sputter on start up?
Posted: Fri Jan 25, 2013 10:42 am
by MaQQu
Check engine coolant temperature sensor or ignition coils.
Posted: Fri Jan 25, 2013 10:44 am
by Shoppinit
Could be a leaky injector. Or a dodgy sensor.
Before starting from cold, check your recorded trim values, and all the values from the temp sensors. Air and coolant.
Might be an air leak. Or heavy drain on the alternator. Try starting with the air con off and headlights, etc off. See if that makes a difference.
/Check your MAF readings when it's spluttering, too. THen at normal idle.
Posted: Fri Jan 25, 2013 10:56 am
by bam_bam
Shoppinit wrote:Could be a leaky injector. Or a dodgy sensor.
Unhelpful prick.
Posted: Fri Jan 25, 2013 7:44 pm
by Keaney
Thanks fellas, It may be my coolant sensor but I have topped my coolant up this week thinkin the sensor could be on its way out.
Shop what do I need to log on vag specifically... I'm not to savvy with it after the fault checks but can prob work it out if its in front of me
Posted: Fri Jan 25, 2013 7:54 pm
by Shoppinit
Keaney wrote:log on vag
*snigger*
Nothing to do with your coolant level. Temperature is what we're interested in. Specifically whether the values are coherent or wonky. Go to advanced measuring blocks and find it in there. I'm not going to explain how to use vagcom, you're gonna have to find someone more patient than me, or use google.
http://www.ross-tech.com/vcds/tour/adv-meas-blocks.html
Posted: Fri Jan 25, 2013 8:02 pm
by Shoppinit
Coolant,Temperature (G62)
Mass Air Flow,(G70) Bank 1
Mass Air Flow,(G246) Bank 2
Engine Speed,(G28)
Intake Air,Temperature (G42)
Throttle Valve Angle
That should do for starters. Log in turbo mode if you can.
Posted: Fri Jan 25, 2013 8:04 pm
by bam_bam
Impatient and unhelpful prick.
Posted: Fri Jan 25, 2013 8:08 pm
by Keaney
No that's spot on Shop thanks for your help
Posted: Fri Jan 25, 2013 11:07 pm
by swannny
bam_bam wrote:Impatient and unhelpful prick.
Everytime I read your posts bam, I automatically picture jack dee saying them in his dry wit way!
Posted: Sat Jan 26, 2013 12:17 am
by bam_bam
That's how it sounds in my head too.
