Page 1 of 3
Rear Numberplate lights not working?
Posted: Sat Dec 22, 2012 8:26 pm
by yorkrs6+
I've Just been fitting various parts of the LED interior kit, came to do the rear Numberplate lights and I'm not sure if they didn't work before I fitted the LEDs or no longer work. Either way with the Original bulbs back in a they still don't work?
Is there a fuse that I can check? If so where is it?
Re: Rear Numberplate lights not working?
Posted: Sat Dec 22, 2012 8:38 pm
by Mr Footlong
Have you reversed either of the bulbs to check? Some LED festoon bulbs do actually require a certain polarity, varies from design to design iirc. Just re-read, unlucky, no idea about fuse for the rear numberplate lights. I take it you have checked the rear brake lights etc all still work? DIS is error-free?
BTW, you should have really posted your post in the main LED thread IMO to help for future searches. I have stuck a link in there for you to hopefully get help quicker.
Posted: Sat Dec 22, 2012 9:10 pm
by swannny
hey yorks,
have you checked to see if there is power there when the lights are turned on?
maybe its just a blown fuse? think its a 5amp,
my allroad had a blown one when i got it, replaced it and never had a problem.
Posted: Sat Dec 22, 2012 9:14 pm
by Shoppinit
DIS doesn't check the number plate lights.
Probably a fuse. I'll have a look.
Posted: Sat Dec 22, 2012 9:22 pm
by Mr Footlong
Sorry, I know it doesn't check those lights, I was referring to rear brake lights etc just in case.
Posted: Sat Dec 22, 2012 9:47 pm
by Shoppinit
Fuse number 4. One of the small ones.
Posted: Sat Dec 22, 2012 9:57 pm
by Mr Footlong
Thanks Shopp, outstanding service as always chap.
Posted: Sat Dec 22, 2012 10:31 pm
by Shoppinit
Does your glovebox light work? Don't forget your side lights have to be on to make it come on.
Must rewire that one day.
Posted: Sun Dec 23, 2012 1:30 am
by yorkrs6+
Thanks for the fuse box diagram/fuse to check
Can someone tell me where to find the fuse box, won't have time to play hide and seek with it tomorrow.
Also ignition was on, side lights and headlights on - made no difference. Swapped led back to original - nothing - no lights
Also glove box led works fine with side lights on.
Posted: Sun Dec 23, 2012 1:36 am
by amanda1
Oh dear open your drivers door and on the side of the dash you will see a d shaped panel the fuses lurk behind
Posted: Sun Dec 23, 2012 8:20 am
by Trups
try and adjust the prongs on the number plate lamp holder, they will more than likely be out of shape and not making a connection.
Trups
Posted: Sun Dec 23, 2012 8:45 am
by yorkrs6+
Connection is v tight, it couldn't get any better - not that
Posted: Sun Dec 23, 2012 10:22 am
by Shoppinit
My money's on the fuse then.
Posted: Sun Dec 23, 2012 11:46 am
by chunky79
So number plate fuse is separate to side light fuse then? If it is, then yes it does sound like your problem.
Posted: Sun Dec 23, 2012 6:15 pm
by Shoppinit
Yup, number plates lights seem to have their own fuse.
