Brake pad warning light
MalcolmSu
Re: Brake pad warning light
Post by MalcolmSu » Tue May 15, 2012 8:16 pm
Chorlton wrote:I'm in Falkirk too!
thanks Chris that's good to know. Drove around all day today with no warning lights - maybe it just don't like Monday's!
I picked up a cable myself today and gave the car a quick scan with VCDS-Lite. Never done this before and slight disappointed (!!) that all it came back with was;
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 4B0 927 156 FB
Component: AG5 01L 4.2l5VT RdW 1315
Coding: 00001
Shop #: WSC 02195
VCID: 6CAB47B30F85
No fault code found.
Address 03: ABS Brakes Labels: 4B0-614-517.LBL
Controller: 4B0 614 517 AD
Component: ESP 5.7 RS 6 03421
Coding: 06697
Shop #: WSC 02195
VCID: 63B92C8FE25B
Should i be worried? :)
Post by Shoppinit » Wed May 16, 2012 8:19 am
Yes, it's missed out about 90% of the modules it shoudl be scanning. Try checking the fault codes in them one by one. Here are the modules you should be checking:
Scan: 01 02 08 15 16 17 35 37 45 55 56 57 65 76
MalcolmSu
Post by MalcolmSu » Wed May 16, 2012 8:19 pm
Shoppinit wrote:Yes, it's missed out about 90% of the modules it shoudl be scanning.
thanks... That was the output from an Autoscan. It's an unregistered copy of VCDS-Lite. The online manual is a touch confusing - on the one hand it states "The unregistered version of VCDS-Lite will scan a very limited number of control modules and then stop." bit then says "Shareware Limitation(s): None. Whether or not VCDS-Lite is registered has no effect being able to communicate with different control modules. Make sure to connect to all control modules that exist in your car, before registering." :?:
Post by Shoppinit » Wed May 16, 2012 9:01 pm
Could be a dodgy cable, or maybe you need to tweak the communication parameters in the settings of VCDS.
MalcolmSu
Post by MalcolmSu » Wed May 16, 2012 9:15 pm
I think Autoscan is limited. Sitting in the car right now scanning the individual controllers you listed. Boringly I've only discovered what I already know so far - TPMS is turned off and I've a faulty parking sensor at the rear left.
Post by Shoppinit » Thu May 17, 2012 11:14 am
You should be pleased!
Of course, not every problem show up as a DTC. Were yuo looking for a problem in particular? If not then you can log your MAFs and boost, to give yuo an idea of health.
MalcolmSu
Post by MalcolmSu » Thu May 17, 2012 8:52 pm
I'm new to VCDS - maybe having had the car for 4 years now is not the time to start 'playing' around with it? I was only having a look to see if the brake pad warning could be switched off permanently through this route. Although it wasn't appeared once since Monday!
Interestingly VCDS told me I had a faulty parking sensor - I cleared the error code and now it's worked everytime since!
I'm off to read how to log my MAFs! Thanks :)
Post by Shoppinit » Fri May 18, 2012 7:31 am
I personally don't think you can turn off the brake pad sensors, but I'm not 100% sure and can't be bothered to find out. :) Let us know.
Users browsing this forum: No registered users and 283 guests
