Petrol / Help / VCDS
Re: Petrol
Yeah, I can't remember if the RS6 was ever able to get the available modules off the CAN controller. Maybe not. I think Steve had this, too. I'll have to try it on mine some time. Doesn't really matter, it's just a pain for autoscans while it tried to communicate with non-present modules.
The only significant fault showing is your coolant sensor. That could totally explain your rough running. It's not labelled "intermittent" (which could indicate a fault code for a fault that's subsequently been rectified), so I assume this is a live fault. But didn't you just replace this sensor?
Try clearing all the fault codes and scan again, just to make sure.
Re: Petrol / Help / VCDS
Hi thanks for coming back to me. I did replace the sensor. I will do as you say and try clearing all codes then run another scan.
Steve
Steve
If that’s the first scan I would be very happy with that.
As Ben has said clear the faults. Run the car for a few days and then rescan to see what comes back.
Wouldn’t be too concerned about the radio or the central locking at the moment. I have both of these error codes.
I would be looking to see if the G62 code comes back.
Especially if you have just replaced it.
I replaced my G62 sensor recently. Like you I had rough running. Sometimes problems starting the car with that error.
Thankfully after installing a new sensor my problem was cured.
Like you I cannot connect with can. I have to select the car from the list.
Okay been out and ran a re test results below. Look same as previous. Both fans on with key at position 1 when running scan.
Saturday,01,February,2025,15:24:01:20920
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WUAZZZ4B54N901020 License Plate: E13SMD
Mileage: 42066 Repair Order: re test
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Address 01: Engine Labels: 077-907-558-BCY.lbl
Part No: 4D1 907 558
Component: 4.2l V8/5VT G 0002
Coding: 0010752
Shop #: WSC 66565 257 00032
VCID: 6B8418848F90EBD29A9-5160
VINID: 9E546AAAA11214478900100200826CDC3A
1 Fault Found:
16501 - Engine Coolant Temp. Sensor (G62)
P0117 - 001 - Signal too Low
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FB
Component: AG5 01L 4.2l5VT RdW 1315
Coding: 00001
Shop #: WSC 02195
VCID: 6C861B988F9EECEA933-516C
No fault code found.
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AD
Component: ESP 5.7 RS 6 2310
Coding: 06697
Shop #: WSC 02195
VCID: 639470A46240A392229-5160
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00001
Shop #: WSC 00189
VCID: 6A8A1D80855AF2DAE1F-258E
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 AA
Component: Airbag 8.4EP 1002
Coding: 0000606
Shop #: WSC 02195 785 00200
VCID: 6FBC0C94BB8817F2B61-5160
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 B
Component: KOMBI+WEGFAHRS. VDO D14
Coding: 01484
Shop #: WSC 37301
VCID: 270C24B456F80FB23E1-5160
WUAZZZ4B54N901020 AUZ7Z0C2485385
1 Fault Found:
01304 - Radio
49-10 - No Communications - Intermittent
Address 35: Centr. Locks Labels:. 4B0-962-258.clb
Part No: 4B0 962 258 N
Component: Zentralverrieg.,DWA D38
Coding: 06859
Shop #: WSC 02195
VCID: 3436C3F8971E742A8B3-4F12
3 Faults Found:
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01561 - Rear left door
61-10 - Won't De-Safe - Intermittent
01134 - Alarm Horn (H12)
77-00 - Internal Supply Voltage
Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl
Part No: 4B0 035 192 K
Component: RNS 4.2 H06 BNO 0140
VCID: 25102EBC2CC41DA20CD-4B02
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02195
VCID: 261229B051C216BA057-514A
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00050
Shop #: WSC 00182
VCID: 04565338873E04AA7B3-4B3A
Address 56: Radio Labels: 4B0-035-192-RNSD-56.lbl
Component: Radio BNO 0001
Coding: 00017
Shop #: WSC 00189
Address 57: TV Tuner Labels: 4D0-919-146.clb
Part No: 4D0 919 146 B
Component: TV Tuner H10~1206
Coding: 0000010
Shop #: WSC 00182 210 83141
VCID: 280E27885ED600CA37B-5160
Address 65: Tire Pressure Labels: 4D0-907-273.lbl
Part No: 4D0 907 273 C
Component: Reifendruckueberw. D310
Coding: 22350
Shop #: WSC 02195
VCID: 270C24B456C80FB23E1-5160
Address 76: Park Assist Labels: 8E0-919-283-8E2.lbl
Part No: 8E0 919 283
Component: Parkingsyst. A6 RDW D09
Coding: 01156
Shop #: WSC 02195
VCID: 6D80169CB4B4E5E284D-5160
End----(Elapsed Time: 04:19, VBatt start/end: 13.3V/11.0V. VIgn 10.9V)-----
www.Ross-Tech.com
75 76 77
Coding: 0010752
1 Fault Found:
Coding: 00001
Shop #: WSC 02195
Coding: 06697
Shop #: WSC 02195
Coding: 00001
Shop #: WSC 00189
Coding: 0000606
Coding: 01484
Shop #: WSC 37301
1 Fault Found:
01304 - Radio
Coding: 06859
Shop #: WSC 02195
3 Faults Found:
35-00 - -
Coding: 00102
Shop #: WSC 02195
Coding: 00050
Shop #: WSC 00182
Coding: 00017
Shop #: WSC 00189
Coding: 0000010
Coding: 22350
Shop #: WSC 02195
Coding: 01156
Shop #: WSC 02195
Selected clear all DTC's and whilst system was running through this could hear a few solenoid clicks and then both cooling fans slowly ramped down. Re Ran the auto scan log file below.
Saturday,01,February,2025,15:32:00:20920
www.Ross-Tech.com
Mileage: 42066 Repair Order: After Clearing Codes
75 76 77
Coding: 0010752
Readiness: 0110 0000
Coding: 00001
Shop #: WSC 02195
VCID: 6C861B988F9EECEA933-5160
Coding: 06697
Shop #: WSC 02195
Coding: 00001
Shop #: WSC 00189
Coding: 0000606
Coding: 01484
Shop #: WSC 37301
Coding: 06859
Shop #: WSC 02195
Coding: 00102
Shop #: WSC 02195
Coding: 00050
Shop #: WSC 00182
Coding: 00017
Shop #: WSC 00189
Coding: 0000010
Coding: 22350
Shop #: WSC 02195
Coding: 01156
Shop #: WSC 02195
End----------(Elapsed Time: 04:38, VBatt start/end: 11.4V/12.1V)-----------
www.Ross-Tech.com
75 76 77
Coding: 0010752
Coding: 00001
Shop #: WSC 02195
Coding: 06697
Shop #: WSC 02195
Coding: 00001
Shop #: WSC 00189
Coding: 0000606
Coding: 01484
Shop #: WSC 37301
Coding: 06859
Shop #: WSC 02195
Coding: 00102
Shop #: WSC 02195
Coding: 00050
Shop #: WSC 00182
Coding: 00017
Shop #: WSC 00189
Coding: 0000010
Coding: 22350
Shop #: WSC 02195
Coding: 01156
Shop #: WSC 02195
Hmm. Weird. You might have a dodgy connection to the coolant sensor.
Clearly i am no expert
and yet to start the car. But I wondered if with the fault logged and not cleared did this keep the fans running as some safety feature?
No, I don't think so.
Open the ECU module only, instead of doing a full scan, and read the fault codes.
And run the engine for a minute then scan again.
What is the difference with this compared to what i have done?
Do i select this from the control module option and do i need to be really careful when in there.
Will do as you say and start the car later.
I really appreciate the support with this... Absolutely crapping my self.
Auto scan scans the whole car. If you go to the engine module then it just scans that one. You can’t do any harm if you’re just checking and clearing codes
Thanks Steve, This was the 1st scan i have completed since having the car. in nearly 5 years.. I was really scared what might flag up. I have said it more than once but without the knowledgeable people in this forum i would be totally lost.steve2003rs6 wrote: ↑Sat Feb 01, 2025 4:34 pmIf that’s the first scan I would be very happy with that.
A massive massive thanks to you guys who have helped me over the past 2 to 3 weeks.
Turned the car over tonight after the completion of the work in my other posts re fans and then a rough idle and support from you on Vagcom.
Car fired up and ran smoothly, battery CTEK MXS5.0 remained at fully charged and the fans did not goto full speed on position 1.
I let the car heat up and with Aircon on the large fan rotated slowly, Small fan off. Aircon off and both fans off.
Not been running for a while so let some heat get into the engine and watched the oil and coolant temperature on the dash slowly come up.
Will scan again
Will scan again
Sounds promising.
I'm thinking that you might have a bad contact on the coolant sensor, or maybe even a faulty one. Where did you buy it? Plausibly, the ECU could put the fans on full because it doesn't know how hot the engine is so reverts to fans full on.
Users browsing this forum: Google [Bot], Majestic-12 [Bot], TOPMAN and 46 guests
