Does anyone know how to activate auxiliary water pump with VCDS?
allroadadi
Post by allroadadi » Sat Jul 26, 2025 2:16 am
Long story short, the electric water pump died under the intake manifold. Not only that but the electrical connector at the water pump has disintegrated. It literally crumbled into little pieces (heat, I’m assuming).
Got a new pump, new connector. I did check the wiring diagram: brown is negative, red/blue is positive. I do want to test it out before I put the manifold back. For those who did it in the past, they know how much of a pain is to remove the manifold. It’s my 3rd time, and I’m still not happy doing it. Not to mention each time I removed the entire front end. Each time though it was for other work as well (timing belt, once, alternator and power steering the 2nd time, etc.)
There’s gotta be a way to test it by using the car electronics and not run power to it (already did that and it’s running). But also want to see if the other parts of this system work so activating it with VCDS would be ideal…
Re: Does anyone know how to activate auxiliary water pump with VCDS?
Post by Shoppinit » Sat Jul 26, 2025 7:57 am
If you can do it, then it will be with the output tests on the ECU module with VCDS. I can't remember off-hand whether it's one of the outputs that's activated. I can check later, possibly.
allroadadi
Post by allroadadi » Sun Aug 10, 2025 1:50 am
Tried it. It does not have the option under the output test. It activates only the SAI pump (secondary air injection).
Looking at the service manual all the tests prerequisites start with engine warm to at least 90C (can’t remember specifically the temperature) if temperature not achieved drive car until temperature is obtained. Then proceed with all tests (electrical, voltage at the connector, etc, or mechanical which is listening).
HPsauce
Post by HPsauce » Sun Aug 10, 2025 1:59 pm
Is this a different/additional unit to the Auxiliary Water Pump in a D2 A8/S8? Because that just runs all the time AFAIK, don't even think you can see it in VCDS.
The only separate way of controlling it is when using the residual heat system when parked as that turns it on so there must be a relay somewhere.
Again, might not be relevant, but the D2 version (which I'd expect to be very similar if not identical) has a habit of getting a very noisy motor and people then usually disconnect the power supply, the water pump suffices for the engine and the cabin heater just takes a little longer in winter.
TOPMAN
Post by TOPMAN » Mon Aug 11, 2025 9:26 pm
You should be able to hear it even from cold. Just tried it on mine, turn the ignition on (no need to start engine) and turn off, put ear to air filter. If you can't hear a slight whirring noise from the pump it's probably not working. It's a hostile environment under that intake manifold and these plastic pumps take a beating. If it hasn't been replaced in its life, I'm quite sure it will need doing. I did mine last year, the same time I replaced the SJP and a bunch of other stuff.
If you remove the airbox, it's the green plug closest to the bulkhead, check it for 12v after a quick ignition flick as mentioned earlier in this post. If you find the 12v supply then you can try supplying directly and see if you hear anything...
Good luck - happy to help if you need :audibash:
Regards
Craig Barlow
TOPMAN
Post by TOPMAN » Mon Aug 11, 2025 9:38 pm
Hello HPsauce
It's a physically a similar pump to the additional coolant pump found on the D2's but the use is different. On the C5 RS6 it is used as an after-run coolant pump, acting in a similar way to an old school turbo-timer, in that it's designed to flow water through the turbos after a drive. It's all controlled by the coolant circulation pump relay which is control by the ECU. This pump actually flows the water in the reverse direction and the idea is to prevent vapour bubbles building up around the area of the turbos. The ECU takes into account variables from ambient temp, oil temp, coolant temp etc etc.
Regards
Craig Barlow
Post by Shoppinit » Tue Aug 12, 2025 10:07 am
Ill have a look on mine later to see if I can find an output test.
Post by Shoppinit » Sun Aug 17, 2025 10:00 am
I couldn't see anything in the Vagcom. You'll have to power it directly to see if it makes a noise.
allroadadi
Post by allroadadi » Thu Aug 28, 2025 2:24 am
As I mentioned I did power the pump with an external power source and it was pumping juice nicely. The problem I had was that the pump plug disintegrated and found the plastic bits under the intake manifold. After studying the diagram I found out the positive and earth wires and bought a new plug, installed it then I tried to test it before installing the manifold back, But couldn’t figure out how to do it using the car electronics so I wound up putting the manifold back on.
Since I am also trying to repair the bumper / washer system and condenser (previous owner hit a possum and destroyed parts of the front end), my car is 90 percent back together, but still not drivable and still did not test out the new pump. Soon though… waiting for some parts/bits for the front end to come in the Mail. It’s so hard in US to source parts for these cars. Lots of assholes on eBay and Facebook marketplace trying to get rich off a 21 year old car selling banged up used car parts. A cracked bumper is thousands of dollars… too bad the Chinese DONT make cheap plastics for these. I would be tempted to buy :bigwave:
You guys DONT know how lucky you are in England…I see good reasonably priced parts for the c5 rs6 on Facebook all the time, but in UK… shipping would be insane especially with Trump wanting his piece of the pie…
Cheers!
Users browsing this forum: Google [Bot] and 61 guests
