Help with sourcing vac lines etc.
Weiß-sechs
Post by Weiß-sechs » Sat May 03, 2025 3:27 pm
So, the inevitable has happened (after racking over 190K miles). Perished plumbing under the the inlet manifold. Obviously, all parts required are NLA from TPS...just wondering if any of you guys have replaced these lines recently & manged to find them? Hoping to do the lot while we're in there including the after run pump if poss. Part numbers gratefully received too.
Any help much appreciated :beerchug:
TechNick
Re: Help with sourcing vac lines etc.
Post by TechNick » Sat May 03, 2025 3:37 pm
@TOPMAN may be able to assist
TOPMAN
Post by TOPMAN » Sun May 04, 2025 10:08 am
TechNick wrote:@TOPMAN may be able to assist Image
Thanks Nick Image
TOPMAN
Post by TOPMAN » Sun May 04, 2025 10:15 am
Weiß-sechs wrote:So, the inevitable has happened (after racking over 190K miles). Perished plumbing under the the inlet manifold. Obviously, all parts required are NLA from TPS...just wondering if any of you guys have replaced these lines recently & manged to find them? Hoping to do the lot while we're in there including the after run pump if poss. Part numbers gratefully received too.
Hi White Six!
Looks like you have a POPPED SJP (suction jet pump). An increasingly common failure these days.
Looks like you’ve done the hard work already, how can I help? What do you need?
Regards
Craig Barlow
allroadadi
Post by allroadadi » Sun May 04, 2025 5:12 pm
Wait, you were able to remove the intake manifold without removing the front end? 🤔
bilko1
Post by bilko1 » Sun May 04, 2025 5:20 pm
Yes you can, I did this job a couple of months ago.
bilko1
Post by bilko1 » Sun May 04, 2025 5:24 pm
@ Weiß-sechs do yourself a favour and change that water pump while you have it apart. The SJP is still available from TPS as used on other VAG cars. Craig (Topman) should have a link for a silicon hose kit I can't find it sorry.
TOPMAN
Post by TOPMAN » Sun May 04, 2025 5:33 pm
allroadadi wrote:Wait, you were able to remove the intake manifold without removing the front end? Image
You most certainly can Image Just unbolt and it will pull forward enough to get the job done Image
Regards
Craig
TOPMAN
Post by TOPMAN » Sun May 04, 2025 5:36 pm
Regards
Craig
Weiß-sechs
Post by Weiß-sechs » Sun May 04, 2025 6:06 pm
Hi White Six!
Regards
Craig Barlow
Ooh, that looks sexy Craig 😍
Looks like you've collected all the pipework needed...silicon hoses? Is there a kit available of all the plumbing needed or did you make a "shopping list" and sourced individually? If you've got linkies or part numbers for all the gubbins, that'd be fantastic my man!
SJP still available then? And, looking at replacing the after run pump while in there (thanks Bilko1)
bilko1
Post by bilko1 » Mon May 05, 2025 4:24 pm
Weiß-sechs
Post by Weiß-sechs » Mon May 05, 2025 6:42 pm
Thank you bud :thumbs:
Shame they're Stateside & not Europe but when needs must...
bilko1
Post by bilko1 » Mon May 05, 2025 7:58 pm
They are in Sweden :biggrin3:
Weiß-sechs
Post by Weiß-sechs » Mon May 05, 2025 8:10 pm
Ahh, thanks man! I was reading the prices in USD haha
Cheers 🍻
Post by Shoppinit » Tue May 06, 2025 8:26 am
:thumbs: Might have to get some of those for future repairs.
Users browsing this forum: asgor, bilko1, Majestic-12 [Bot] and 65 guests
