Slow/stiff steering
Marcin
Re: Slow/stiff steering
Post by Marcin » Mon Mar 31, 2025 7:24 am
Felix2566 wrote:
Tue Mar 25, 2025 11:32 am
Just realised I never closed this off, the system took a couple days to fully bleed itsself out and not have loads of tiny bubbles in the reservoir.
But is all working perfectly now, no noise, smooth action as it all should be.
I was lucky to get the all air out quickly enough through this steps. It might help someone in the future:
1 - Top up the power steering oil and turn the steering wheel left/right 15 ish times with engine OFF (wheels of the ground)
2 - Turn ON the engine and slowly do the same.
3 - Turn OFF the engine and let the air escape with reservoir cap off (1h) you can do your tie rod ends in the meantime or drink a tea.
4 - Whith the engine OFF slowly turn the steering wheel L/R a couple of times you will see significant amount of air escaping through the reservoir.
5 - Top up the fluid and off you go.
This worked for me, no cavitation or funny noise from the PS pump.
Is:
2003 RS6 | 2013 A6 BiTDI quattro | 2016 Corsa ;) | Suzuki GSX-R 1000 K6
was:
2004 A6 3.0TDI quattro | 2000 A6 1.8T quattro | 1997 A6 1.8 | 1998 Opel Vectra 1.6 | 1985 VW Santana |
Felix2566
Post by Felix2566 » Mon Mar 31, 2025 7:07 pm
Thanks for posting that, I have a feeling I didn't do the moving with the engine off....
Users browsing this forum: Capt Ric and 58 guests
