ground wire
markmark
ground wire
Post by markmark » Fri Jan 10, 2025 10:03 am
Hi, I have a problem with starting the engine – the symptom is as if the battery is weak, but the battery is new. I figured out that the issue is due to a lack of proper ground connection to the engine – when I directly connect the engine to the car body, I am able to start it. Does anyone know where the main engine-to-body ground connection point is?
111marc111
Re: ground wire
Post by 111marc111 » Fri Jan 10, 2025 10:53 am
Look around the starter motor area. Which is uk drivers side.
Look from under the car up at that side chassis leg and there is a large ground connection bolted up to the underside of that chassis leg. 13mm nut if i recall.
In amongst that is a few cables that head down to the alternator and the starter motor.
Under the starter motor just above the sump is a large ground connection to the block. Cap head bolt with 6mm Allen head if I'm not mistaken.
Have a look. If your still struggling I can probably get you pics off mine.
cover99
Re: ground wire
Post by cover99 » Sun Jan 12, 2025 11:15 pm
I had a quick look under mine can see one end at/around the alternator...other end disappears :) Could you post up pictures? Thanks Steven
bilko1
Re: ground wire
Post by bilko1 » Tue Jan 14, 2025 6:05 pm
It goes from the rear of the starter bracket to the chassis leg above the alternator. I've just removed the alternator as it decided to pack up after doing the cambelt :audibash: :audibash: :audibash: If you need better pictures I'll get them when its light.
Re: ground wire
Post by Shoppinit » Tue Jan 14, 2025 6:42 pm
111marc111
Re: ground wire
Post by 111marc111 » Tue Jan 21, 2025 4:32 pm
Sorry for the delay. Not had chance to get near the car. See pics if you havent found them and solved it already
cover99
Re: ground wire
Post by cover99 » Fri Jan 24, 2025 8:01 pm
Thanks for this will have a wee look..... When the wind dies down a bit. Always good to know where they are. Thanks
